Toymods » Tech & Conversions » Low compression on a high-compression 4AG
flamingheads
QLD, Sunshine Coast
August 2005
Low compression on a high-compression 4AG Sat, 10 December 2005 01:59 Go to next message
My new 100kw 4AG apparently had new rings fitted about 7000 kms ago and has high compression pistions but when a mechanic did a compression test it was only 90-110 psi. I read that standard compression for these engines is about 180 psi so with high compression pistons it should be higher than this.
The mechanic said there is a good chance that having the valves adjusted could bring compression up to about 180psi but thats still only normal compression.
The guy I bought the car offs theory is that the engine only gets its power above about 3000 rpm so compression might be lower below that but the mechanic doesn't think so.
Does anyone know anything that could explain this? Are any of these theorys right? Will adjusting the valves give it full compression? Any help would be good thanks.
jeffro RA28
Tamworth
Re: Low compression on a high-compression 4AG Sat, 10 December 2005 03:16 Go to previous messageGo to next message
If ur valves are being held open thanx to zero valve lash then u will get a low comp reading.
If that doesnt work try lightly hitting the top off the valves, this may dislodge any junk on the valve seats that is holding the valves open.
Giving it a leakdown test may also help to find the problem
[Updated on: Sat, 10 December 2005 03:17]
yrhkira
June 2005
Re: Low compression on a high-compression 4AG Sat, 10 December 2005 04:07 Go to previous message
Is the motor stock? Are all four cylinders in the same range? The pressure readings are low if it is a stocker.
Anyway, compression pressures and compression ratios do not directly relate.
There is more to it than a direct relationship. That is pressure does not necessarily go up if the compression ratio is increased.
Other factors come into play, such as valve lift and timing.
All pressure readings are usually taken at cranking speeds, so a high compression ratio motor can have low pressure readings especially when the inlet valve lift is great or it has a long duration and late closing.
At cranking speeds a lot of air can be pushed back out of the inlet valve so there is not much to build any pressure. A full competition motor with high lift and long duration valve timing allows a lot of air back out at cranking speeds but the actual dynamics of the air/fuel gas flow at normal running engine speeds actually draws more air/fuel in even though the piston is moving up the bore during the compression stroke.
If the engine runs smoothly I would say it has some valve clearance.
Adjusting the valve clearance can change the pressure at cranking speeds as it changes the timing and lift of the valve. More clearance on the inlet will give, in theory a slight increase in pressure but it would be hard to measure a difference.
Check the inlet valve timing to see if it has been retarded which will mean the valve is still open too late in the compression stroke.
Regards
Rodger
Previous Topic:4age electrical problem
Next Topic:SW20 conversion-Accelerator Cables
Current Time: Mon Nov 16 01:00:22 UTC 2026
Total time taken to generate the page: 0.048928022384644 seconds
