Classifieds » Parts Wanted » Wiring diagram for Delco ECU
7mgtema71
Wiring diagram for Delco ECU Tue, 21 January 2003 01:23 Go to next message
as the title says guys, thanks
Frank
supra7mgte@hotmail.com
Grega
melbourne.victoria.austra...
Re: Wiring diagram for Delco ECU Tue, 21 January 2003 06:02 Go to previous messageGo to next message
which delco? 1227808 from VN?
i have several, ranging from N13 Pulsar, to JE Camira to VN Commodore...let me know which one you want..
SupraPete
Re: Wiring diagram for Delco ECU Wed, 22 January 2003 06:17 Go to previous messageGo to next message
Who's programming it? I've got a great programmer (got 166kW out of his 3TGTEU on the dyno day. and that hadn't had a tune for about 2 years!)
I'm putting delco on my supra
RobR
Re: Wiring diagram for Delco ECU Wed, 22 January 2003 10:43 Go to previous messageGo to next message
which delco ecu would be better to use on my 22R turbo?
SupraPete
Re: Wiring diagram for Delco ECU Wed, 22 January 2003 22:19 Go to previous messageGo to next message
They're pretty much the same 'cept the V8 has nock sensors and a different ignition module. Also the computer on the v8 controlls the gearbox too.
I got one out of a JE camira for $150 (pulled it out, and ALL sensors myself) we've wired in 2 of the v8 ignition modules, and no nock sensors yet.
Everything can be added later. Your better off using the Camira one as its smaller and doesn't have as much in it. It will also have a good ignition module for the 22R.
It really depends on who is tuning it?? Seriously this guy is a wizz with delco!
7mgtema71
Re: Wiring diagram for Delco ECU Wed, 22 January 2003 22:35 Go to previous messageGo to next message
Why the V8 ignition module? I gathered the STD JE camira ignition module was sufficient enough. I was thinking of using the std ignition module and use a pair of V8 coils...
SupraPete
Re: Wiring diagram for Delco ECU Wed, 22 January 2003 22:46 Go to previous messageGo to next message
The camira ones are fine. Has something to do with the degrees before firing or something. I'm getting a box made up to convert a lot of signals into what the delco needs, really complicated and Dick told me to get two v8 modules, and he knows his stuff bloody well.
I'm using two as the 1uz has 2 coils and 2 distributers (kinda) so I needed two ignition modules.
roger
Re: Wiring diagram for Delco ECU Thu, 23 January 2003 03:07 Go to previous message
VN V6, V8, and JE camira ECU are all the same. The V6 and HSV V8 have a knock module on the memcal. The knock module is next to useless for any other engine than it was designed for. You use the V8 module when you need to runing 2 coil ie duel channel module. The standard camira one is single chanel. Hope this clarifies some myths.
Roger
[Updated on: Thu, 23 January 2003 03:07]
Previous Topic:WTD: JZX81 Chaser radiator
Next Topic:RA23 door skin
Current Time: Wed Oct 21 02:57:25 UTC 2026
Total time taken to generate the page: 0.0055229663848877 seconds
