Toymods » Tech & Conversions » AE86 4AGE Cooling System Leak
fOOZ86
AE86 4AGE Cooling System Leak Tue, 21 January 2003 03:42 Go to next message
Hey all, I've got a little problem with my car, there seems to be a pretty bad leak somewhere around the waterpump... I'm having a few problems trying to locate it exactly, but it's somewhere in that area.
It drips down onto the top of the sump right next to the crossmember and just behind the alternator.
when I squeeze the radiator hoses it drips out but I just can't find the source of it, I've checked all the hose connections as best I can.
Would it be that the actual waterpump is leaking? it's about.. 3-4 months old. oh it's the TVIS motor with belt driven fan and water pump.
Also, what's the best way to get to that area of the engine? Do I have to remove the inlet manifold and all that?
Thanks, Grant.
IRA11Y
Club Member
Re: AE86 4AGE Cooling System Leak Tue, 21 January 2003 06:25 Go to previous messageGo to next message
sounds like the front seal on the pump might have gone, look from underneath to see if you can see water dripping out of the little relief hole, in which case youll need to replace the front half of the pump
fOOZ86
Re: AE86 4AGE Cooling System Leak Tue, 21 January 2003 09:07 Go to previous messageGo to next message
to look at the bottom of the water pump I've either gotta remove the alternator or the waterpump itself right?
fOOZ86
Re: AE86 4AGE Cooling System Leak Tue, 21 January 2003 10:36 Go to previous message
Anyone got any advice for this? I've had a crack at it but uhm, I have to take off the bumper bar n take the radiator out?
My hands are already covered in scartches, lol.
Previous Topic:need help? damaged 4agze
Next Topic:Help, advice needed for dead 5ME in MA61
Current Time: Fri Nov 20 05:41:48 UTC 2026
Total time taken to generate the page: 0.0059440135955811 seconds
