Toymods » Tech & Conversions » 4age running poorly
JDM-086
4age running poorly Mon, 12 December 2005 10:00 Go to next message
ill keep it as short and concise as possible:
-down low the car barely pulls and actually goes worse if u put foot to the floor rather than gradually letting onto the accelerator
-in first and second the car picks up considerably after 4.5gran revs but in 3rd,4th and 5th it struggles a fair bit
-car is running lean
-pings slightly wen pushed
now this is wat ive done to fix the issue but so far hasnt worked:
-changed fuel filter,spark plugs, fixed exhaust leak.
-there was no o2 sensor, hooked another single wire toyota o2 sensor
-checked ignition timing and it was set to 20degrees, wen totally retarding it the lowest we could get it to was advanced 20 degrees, so we pulled the dizzy out and skipped it over 1 tooth and then wen couldnt get it any higher than 5degrees advanced ( im thinking the cam timing could b out).
if any 1 has any ideas as to wat the problem is, help would b much appreciated (if any1 also knows of any good mechanics or anything like that, that work on these engines plz let me know)
[Updated on: Mon, 12 December 2005 13:12]
xolent
Re: 4age running poorly Mon, 12 December 2005 10:13 Go to previous messageGo to next message
it's that 1 tooth
xolent
Re: 4age running poorly Mon, 12 December 2005 10:14 Go to previous messageGo to next message
i went with the procedures with aligning the indents and it was like yours
then i just said "fuck it i'll just shove it in my way and see what happens" and it worked
JDM-086
Re: 4age running poorly Mon, 12 December 2005 10:19 Go to previous messageGo to next message
yer 1 tooth seemed to b like 15 degrees, it was either 20 or 5
JDM-086
Re: 4age running poorly Mon, 12 December 2005 12:10 Go to previous message
any help would b awesome right now, i tried to search and found a few similar cases but nothing exactly like this with a solution
Previous Topic:sard vs greddy typre rs
Next Topic:Aircon help
Current Time: Sat Oct 31 14:18:44 UTC 2026
Total time taken to generate the page: 0.12464094161987 seconds
