Toymods » Tech & Conversions » WHen did Toyota start puting in Rev Limiters?
Celia-Sue
WHen did Toyota start puting in Rev Limiters? Tue, 21 January 2003 04:57 Go to next message
And on what cars?
And more specifically, is there a rev. limiter on the 1UZFE Crown? In Aus. spec. or JDM?
Bloody PITAs!!!
- Justin
http://www.celicasupra.com/justin.htm
SUPRAGTE
North Sydney
Re: WHen did Toyota start puting in Rev Limiters? Tue, 21 January 2003 09:51 Go to previous messageGo to next message
They started putting in rev limiters on cars pretty much the same time as crank angle sensors were installed as it made it very easy to put it in the ECU code.
7MGTE came out around 86-87 so then.
Re: WHen did Toyota start puting in Rev Limiters? Tue, 21 January 2003 23:51 Go to previous messageGo to next message
The 1UZFE is rev-limited at something annoying like 6500rpm if I remember correctly?
My 21R-C cuts out at this...but you'd expect that Razz
ed_ma61
Lost in the K hole
Re: WHen did Toyota start puting in Rev Limiters? Wed, 22 January 2003 01:57 Go to previous message
7m-ge NON CAS (dizzy) 1986.5-1988 early ecu model even has one (manual only)
btw, did the EARLY 7m-gte's have a CAS? thought they also had a dizzy there for a while (well some did)
cheers'
ed
Previous Topic:Cressida conversion 1jz-gte vs 2jz-gte
Next Topic:What compression is safe for boost??
Current Time: Fri Nov 20 10:25:32 UTC 2026
Total time taken to generate the page: 0.0051329135894775 seconds
