Toymods » Tech & Conversions » GZE cutting out over 5PSI
old_mr2
GZE cutting out over 5PSI Mon, 12 December 2005 15:01 Go to next message
Well as the title says my afm gze is cutting out when i give it some boost. over 5 psi basically. She just shunts backwards and a feeling that she is running on 2 cylinders, makes an unhealthy noise too. Exhaust pops when throttle is lifted and she runs fine again at low rpm.
I am thinking:
spark plugs (these have now been replaced, problem still apparent)
fuel filter
fuel pump
maybe dodgy afm
It used to only happen on very hot days +35 deg c
or when i had crappy fuel in it.
NOW it happening all the time no matter which 98 octane i use and all air temps. I have no leaks in my piping.
oh and it only happens after car has been at operating temp for 5 minutes or more.
[Updated on: Mon, 12 December 2005 15:07]
-=DV=-
Newcastle, NSW
Re: GZE cutting out over 5PSI Mon, 12 December 2005 17:31 Go to previous messageGo to next message
check for boost leaks man, after that, pull ur error codes and see what ur ecu is telling u..cheers
myne
October 2005
Re: GZE cutting out over 5PSI Mon, 12 December 2005 20:52 Go to previous messageGo to next message
knock sensor.
Got a working engine warning light?
It'll stay on while you drive if thats what it is.
I'd also suspect an air leak. 5psi is nothing
feral4mr2
Bundaberg, Qld.
Re: GZE cutting out over 5PSI Mon, 12 December 2005 23:39 Go to previous message
aw11 gze will still boost over 5psi with a faulty knock sensor.
as -=DV=- said, check for any ecu codes, should be one of the first things you do when your having some problems.
Previous Topic:What is a 'Group A' 4AGE ?
Next Topic:soarer speedo wiring
Current Time: Tue Nov 17 22:49:15 UTC 2026
Total time taken to generate the page: 0.0054459571838379 seconds
