Toymods » Tech & Conversions » Bellhousing for early SV21 V6 Camry motor.
Grega
melbourne.victoria.austra...
Bellhousing for early SV21 V6 Camry motor. Mon, 12 December 2005 19:38 Go to next message
All, does anyone know if there is a bellhousing available to adapt a W5x RWD box to the 2.5 litre camry V6 (the one from the early 90's)
Is there such a beast that anyones aware of, or, is it time to build one?
evoX3
November 2005
Re: Bellhousing for early SV21 V6 Camry motor. Mon, 12 December 2005 21:44 Go to previous messageGo to next message
check the Hilux V6 boltpattern
Grega
Re: Bellhousing for early SV21 V6 Camry motor. Mon, 12 December 2005 23:32 Go to previous messageGo to next message
from what i've searched on ect folks seem to think the hilux use a R150 which attaches to the xMZ series of motor.
to get fairly specific here ; i'm thinking 2VZ - although i've read that maybe a 2S bell will suit.
don't really wanna run a R154 (too big)
Grega
Re: Bellhousing for early SV21 V6 Camry motor. Tue, 13 December 2005 01:28 Go to previous messageGo to next message
looks like 2S bell is the way to go. if you can find a flywheel
Re: Bellhousing for early SV21 V6 Camry motor. Tue, 13 December 2005 02:01 Go to previous messageGo to next message
S or Hilux housing will do you job. Almost. The starter will end up trying to get friendly with the head however, you need to do a little adapting. The 3VZE Hilux motor is a single cam per bank engine, and the heads are narrower.
Pube
Camden
Re: Bellhousing for early SV21 V6 Camry motor. Tue, 13 December 2005 02:56 Go to previous message
i have a 3VZ R15* belhousing that i was planning to use with a 2VZ but i couldnt find a 2VZ! If you are interested give me a yell as i have no use for it. Also the R150 is out of the current 4.0L RWD hilux and uses an integrual bellhousing.
Previous Topic:Replacing shocks
Next Topic:4age inlet manifold q?
Current Time: Tue Nov 17 21:58:19 UTC 2026
Total time taken to generate the page: 0.0038459300994873 seconds
