Toymods » Tech & Conversions » calibrating speedo with w55 & ra28 speedo stock diff
calibrating speedo with w55 & ra28 speedo stock diff Tue, 21 January 2003 10:03 Go to next message
Hello, just wondering if anyone has had much luck with putting a w55 into a ra2x with stock speedo and diff and getting it calibrated?
I find it to be about 20% out or so, 100km would show on the speedo as 120 etc.
I thought tonight maybe the original sender out of the w50 would fit so pulled the w55 sender out but are completely different in shape and size.
Any ideas?
Joel
Bugman
Re: calibrating speedo with w55 & ra28 speedo stock diff Tue, 21 January 2003 10:06 Go to previous messageGo to next message
I heard there are about 5 different senders... but I found my 58 to be quite accurate, just as accurate as the 50 used to be
Re: calibrating speedo with w55 & ra28 speedo stock diff Tue, 21 January 2003 10:08 Go to previous messageGo to next message
Ahh you must have got the correct one.. Guess there is different amounts of teeth etc and would depend on diff ratio.
Any ideas where there might be a source of different senders? Doubt importers would like selling them individually.
Bugman
Re: calibrating speedo with w55 & ra28 speedo stock diff Tue, 21 January 2003 10:35 Go to previous messageGo to next message
if it helps the w58 was meant to be mated with a 4.556 diff gears.
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: calibrating speedo with w55 & ra28 speedo stock diff Tue, 21 January 2003 12:31 Go to previous messageGo to next message
Yeah man, I'm in the same boat. Alot of people reckon you can't get different senders, but I reckon I've heard theres a few different ones too.
The other option is a little reduction gearbox, which I've been quoted $200 for!!! I laughed about as hard as you must be right now!
Although that place called gauge works, been advertising recently, I've been thinking of trying them. But that's sorta been put on hold, as you might understand.......
Re: calibrating speedo with w55 & ra28 speedo stock diff Wed, 22 January 2003 01:27 Go to previous messageGo to next message
You need to find a vehicle which has a W5x transmission and the same diff ratio as you currently have. Simply take the nylon speedo gear out of that transmission and whack it in your W55. That should solve all your problems!
If you currently have a 4.1:1 diff, you should find what you're looking for in an RA6x Celica.
rob_RA40
c'town, NSW
Re: calibrating speedo with w55 & ra28 speedo stock diff Wed, 22 January 2003 01:57 Go to previous messageGo to next message
manual RA60 came out with 3.9 diff ratio
Re: calibrating speedo with w55 & ra28 speedo stock diff Wed, 22 January 2003 03:07 Go to previous messageGo to next message
RA6x's came with a variety of diff ratios. I'm almost certain I've seen at least one with a 4.1:1 diff.
rob_RA40
c'town, NSW
Re: calibrating speedo with w55 & ra28 speedo stock diff Wed, 22 January 2003 04:17 Go to previous messageGo to next message
be cool norbs, i aint saying your wrong, was just adding that the manual RA60 came with 3.9 Very Happy
although i suppose it wouldnt be the toymods forums if there wasnt an argument going on so i say norbie you are wrong i have difinitive evidence that the RA60's never came in 4.11 ratio, the evidence is from a website that has expired long ago in a galaxy far far away Laughing Surprised Shocked Rolling Eyes
CamZH
Toodyay, WA
Re: calibrating speedo with w55 & ra28 speedo stock diff Wed, 22 January 2003 07:37 Go to previous message
You should be able to get differnet speedo drive gears...
In the Ford world there gears were colour coded for different diff ratios.
2.75:1 is a reddy brown colour from memory Smile
stuffed if i can remember the others!
CamZH
Previous Topic:Need help on list of parts for conversion
Next Topic:I cant locate the coil for a 4afc engine. TACHO installation
Current Time: Fri Nov 20 12:42:46 UTC 2026
Total time taken to generate the page: 0.0090029239654541 seconds
