Toymods » Tech & Conversions » Question about AFM adjustment screw on AE86?!?!
pwrupae86
Question about AFM adjustment screw on AE86?!?! Sat, 08 June 2002 01:36 Go to next message
is it true that the adjustment screw on the afm should be all the way down in its stock setting. mine was 3/4 of the way up for some reason.....could this be a reason why i'm running rich? thanks.
mr_mcfarlane
Canada
Re: Question about AFM adjustment screw on AE86?!?! Sun, 09 June 2002 22:24 Go to previous message
the afm idle screw should not be completely closed or open. where are you rich? just at idle? or all the way thru the rev range? the greater the modification of the motor, the less the afm idle screw does.
to check rich condition, use meter or DVM on o2
if rich under cruise, light throttle. your prob is not the screw
Previous Topic:Any opinion/advice on a 1JZGTE swap into AE86?
Next Topic:Bill sherwood or anyone pls help
Current Time: Wed Nov 18 14:53:12 UTC 2026
Total time taken to generate the page: 0.0049920082092285 seconds
