Toymods » Tech & Conversions » Oil cooler lines???
MaNGeW
Formerly TRD_RoLLa
icon4.gif  Oil cooler lines??? Wed, 22 January 2003 01:09 Go to next message
just one quick question..
would u know what kind of hoses are sufficient for oil cooler lines?
to be mated up to a 4agze block.
would rubber fuel lines do the job?
or do i need braided?
ed_ma61
Lost in the K hole
Re: Oil cooler lines??? Wed, 22 January 2003 01:41 Go to previous messageGo to next message
you running a pressurised or non-pressurised cooler?
if non pressurised, just normal rubber hose with utilux type hose clamps is fine. you might want some thermal insulation (thermal sleeve braiding) to protect the rubber from block radiant heat, but thats all.
as for pressurised, youll need propper pressure rated hose with propper fittings, and a cooler to suit. still doesnt have to be brainded line, but just pressure rated. again, some thermal insulation woulndt go astray.
ed
MaNGeW
Formerly TRD_RoLLa
Re: Oil cooler lines??? Wed, 22 January 2003 04:11 Go to previous messageGo to next message
Umm im not to sure whether its pressurised oil or not???.
Its basically the same setup as the 4age has with oil cooler.
The oil flows through a sandwich plate where oil filter is and is directed thru the oil cooler then cooled oil returns back into the oil sump.
I think this is how my intended setup works.
Would it be pressurised since already passing thru the oil pickup and pump?
CamryMan
Re: Oil cooler lines??? Wed, 22 January 2003 10:46 Go to previous messageGo to next message
Last time I asked about an oil cooler, Fabre were recommending I use braided hoses.
clubagreenie
1st street on the right
Re: Oil cooler lines??? Wed, 22 January 2003 11:01 Go to previous messageGo to next message
If it's through a sandwich plate on the filter then it's under pressure, not return. You don't need braided hose but I would recomend "oil ooler hose" Like most hose it has braid embeded inside the rubber. Try at your local enzed or pirtek and get some hyraulic hose. It's more than enough for the temp, oil and pressure. Next time you see one on the road pull them over or call the mobile on the van. The mobile guys usually have offcuts I've bought cheap in the past. They can even crimp the fittings for you if needed.
haggis
Re: Oil cooler lines??? Thu, 23 January 2003 22:58 Go to previous messageGo to next message
Dont foget to add enough extra oil to your car to account for what will sit in the cooler and lines!
Craig.
rollaboy
Coffs
Re: Oil cooler lines??? Fri, 24 January 2003 13:09 Go to previous message
I just got a sandwhich plate for my oil cooler setup and the oil lines have been uncovered for a while now so should i pull the cooler out and give it a clean out with something and the lines to??
What would i use to clean it??
Brett
Previous Topic:what is the maximum RPM for a 4afc engine???
Next Topic:Corona ST141 (2SC) Vacuum Advance (1986 model)
Current Time: Mon Oct 26 17:02:57 UTC 2026
Total time taken to generate the page: 0.005396842956543 seconds
