Toymods » Tech & Conversions » 1ggte overfueling
ddeane
PNG
1ggte overfueling Wed, 22 January 2003 22:13 Go to next message
Just chasing some advice.
Changed the engine on the 23 over xmas. The previous engine was running ok, just had a blown head gasket, but showed no signs of overfueling. I was replacing a mk2 engine with a mk3 engine, so I swapped long motors retaining only the exhaust manifold and the inlet manifold. This means that I retained the existing turbos, throttle body, sensors, fuel rail, injectors, etc.. One reason for this is that the loom on the mk3 is different - different computer plugs, injector plugs, sensor plugs.
So having set the scene - as the car comes on boost it gets soft and starts blowing out great clouds of black smoke (fuel). It seems to be better on full boost, although some times it can be soft there and have problems getting over 10psi.
Initial thoughts are a leak in the inlet piping (that is between the turbo and the throttle body) that is bleeding off boost but the airflow meter would still be asking for lots of fuel. Can't find it though - may have to strip out the grill and have a real good look. I have tried spraying carby cleaner everywhere to see if it is sucking air off boost but as it is idling great not sure that I have any hope here.
Any further ideas???
Craig
Bugman
Re: 1ggte overfueling Thu, 23 January 2003 05:56 Go to previous messageGo to next message
yeah my one is running rich too, on the dyno it dipped below 10:1, but I got the thought that sensor was screwy as it died on the next few runs and they had to replace it with a newy.. my idle aint perfect so I'm hunting leaks... finaly got a guage on the boost too and it is like how you describe... car drives fine though.
Dylo
Re: 1ggte overfueling Thu, 23 January 2003 07:07 Go to previous messageGo to next message
Hey Bugman,
What sensor was it that was stuffed on yours? mine also runs rich, and it puffs fuely smoke out at idea!
But can anyone help me here: ......it hunts a little bit on idle (up and down) , and then it sorts its self out, BUT if u touch the accelerator again it has hunt and fix itself all over again!!
Sorry i cant help you out a bit craig. but im stumped here too!!
Bugman
Re: 1ggte overfueling Thu, 23 January 2003 08:48 Go to previous messageGo to next message
I think I found a leak ths arvo from the booster line. the bost seems to hold steady now at about 9-9.5psi at the inlet manifold which is about right, given a 1psi drop across the stock coler. seems to ideal smoother but I'll give it a bit of a run before I'm satisfied.
also my boost guage(if you could call it that) only read positive pressure so I'm not sure how smooth the ideal vacum is.
feral4mr2
Bundaberg, Qld.
Re: 1ggte overfueling Thu, 23 January 2003 11:12 Go to previous messageGo to next message
Freakhey guy's i have a Q about your 1g-gte engine.
i have a friend in the carrabean who has asked me to chase up a full gasket kit for one of these engines.. i have looked through all the books at work, and even rung a toyota mob. they didnt seem to be able to find a gasket kit for one of these engines at all....
so is it a fully imported engine? where do you guy's get bit's from for this engine?
thanks..... Smile
gold28
Madrid - Spain
Re: 1ggte overfueling Fri, 24 January 2003 02:54 Go to previous messageGo to next message
feral4mr2
It is an imported engine, never sold in Aus and as far as I know never sold outside of Japan.
Apparently the IS200 Lexus has a 1G-GE in it, but I am not sure if the head gaskets are the same. I would have thought the Turbo ones would be copper or at least stronger.
You need to track down a toyota dealer that has an import spares department. I know that Castle Hill Toyota in Sydney has an import department and can get the parts, however they don't really stock anything, so you still have to wait for delivery from Japan.
Good Luck
Bugman
Re: 1ggte overfueling Fri, 24 January 2003 03:06 Go to previous messageGo to next message
the is200 had a 1g-fe, different head design, have the close angle cams.
ddeane
PNG
Re: 1ggte overfueling Fri, 24 January 2003 04:11 Go to previous messageGo to next message
Canberra Toyota at Phillip as for Malcomb. Or Sean Moloney (IDB) in Melbourne 03 94285277
feral4mr2
Bundaberg, Qld.
Re: 1ggte overfueling Fri, 24 January 2003 05:45 Go to previous messageGo to next message
Freak cheers guy's....
i'll give them a go, otherwise he might have to try Japan direct or US of A....
Bugman
Re: 1ggte overfueling Fri, 24 January 2003 05:47 Go to previous messageGo to next message
I've red a few mags and seen whole page add for companies who sell gaskets for all manner of motors and noticed they had the 1g-gte listed.
TOY77
Re: 1ggte overfueling Fri, 24 January 2003 09:37 Go to previous messageGo to next message
mine idles fine....
bout 20 in of vac from memory but dead steady.....
with the hunting idle check for loose earth (that was mine) or vac leak...
Stew
Dylo
Re: 1ggte overfueling Mon, 27 January 2003 09:21 Go to previous messageGo to next message
TOY77,
Which earth was causing you the problem?
TE72_Turbo
Re: 1ggte overfueling Mon, 27 January 2003 12:36 Go to previous messageGo to next message
hunting at idle can also be caused by a lean mixture
or burnt valves
or obviously a vacuum leak or idle air metering problem
Phil
TOY77
Re: 1ggte overfueling Mon, 27 January 2003 23:21 Go to previous messageGo to next message
heya,
the big earth on the side of the plenum.....
that earths the computer, the ignitor and coil...etc...
oh well all is good now and pulling like it should!
Stew
cressTT
Re: 1ggte overfueling Tue, 28 January 2003 02:28 Go to previous messageGo to next message
I put my money on Intake plumbing leak....do the intake pressure test....I did the test onh my VR4 and found small seepage leaks which is only visible under boost....
havent try it on my 1G-Gte tho..the process should be the same...
http://www.vfaq.com/mods/ICtester.html
ddeane
PNG
Re: 1ggte overfueling Tue, 28 January 2003 03:51 Go to previous messageGo to next message
Thanks. Will make one tonight.
ddeane
PNG
Re: 1ggte overfueling Thu, 30 January 2003 09:01 Go to previous messageGo to next message
It ended up costing me $290 to find my problem!! Booked the car into Evo in canberra - appears as though in the 3 days that I was fitting the new engine a wasp built its nest in the fuel return line. Wolla - ended up with 100psi fuel pressure and so overfueling. By the time they had found that and replaced all of the hose, filter and clamps I was up for shitloads.
Craig
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
icon9.gif  Re: 1ggte overfueling Thu, 30 January 2003 23:56 Go to previous messageGo to next message
Holy shit! The things that happen eh?
At least you've fixed it now.
We still haven't met up since I've been in Canberra! Maybe I should organise another get together down here...
ddeane
PNG
Re: 1ggte overfueling Sat, 01 February 2003 05:26 Go to previous message
Max
Sounds good to me.
Craig
Previous Topic:TOYOTA NATIONALS
Next Topic:1ggte wiring! what am i doing wrong (i heard traction issues knows a fair bit)
Current Time: Fri Nov 20 13:06:32 UTC 2026
Total time taken to generate the page: 0.0075540542602539 seconds
