Classifieds » Miscellaneous » AE101 Levin GTZ Front and AE92 SX Rear Brakes and Rotors for Sale
AE82TwinCam
Canberra, ACT
AE101 Levin GTZ Front and AE92 SX Rear Brakes and Rotors for Sale Thu, 23 January 2003 08:12 Go to next message
I have a set of AE101 Levin GTZ 275mm diameter, 25mm think and vented discs and Twin spot calipers for sale. Brand new pads on calipers.
I have measured the thickness off the rotors and they are still 25mm, so they still have alot of life left in them Very Happy
$200
I also have a set of AE92 SX rear discs and that are approx 260mm in diameter and calipers for sale
$75
I am in Canberra
PM or phone me on 0402325926
-Andrew
[Updated on: Sat, 25 January 2003 10:11]
GTI16V
CROMER, NSW
Re: AE101GTZ Brakes and Rotors for Sale Fri, 24 January 2003 09:51 Go to previous messageGo to next message
Have a friend who is interested could you give me a call on 0402325786 and i'll get him in contact with you
Regards
Paul
AE82TwinCam
Canberra, ACT
Re: AE101 Levin GTZ Front and AE92 SX Rear Brakes and Rotors for Sale Sat, 25 January 2003 10:13 Go to previous messageGo to next message
I will do 50/50 C.O.D if that helps..
-Andrew
bass_boy
Re: AE101 Levin GTZ Front and AE92 SX Rear Brakes and Rotors for Sale Sun, 26 January 2003 00:43 Go to previous messageGo to next message
what would i need if i wanted to convert my rear drums to use these discs?? is it a hard job? would it be best for the mecanic to do it? if its do-able then i will buy the rears...
AE82TwinCam
Canberra, ACT
Re: AE101 Levin GTZ Front and AE92 SX Rear Brakes and Rotors for Sale Sun, 26 January 2003 01:31 Go to previous messageGo to next message
I would assume you need the rear disc hub assembly off an AE92 SX corolla (I only have 1) first if u wanted to convert to discs on the rear.. the handbrake may be another issue though, I am not sure of the actual differences in the connections for the handbrake..
It something you may want to ask your mechanic about since I own an ae82 and never had to convert from drum to disc.. somoene on the forums should know though Smile
-Andrew
bass_boy
Re: AE101 Levin GTZ Front and AE92 SX Rear Brakes and Rotors for Sale Sun, 26 January 2003 05:25 Go to previous messageGo to next message
can anyone answer this for us???
rollaboy
Coffs
Re: AE101 Levin GTZ Front and AE92 SX Rear Brakes and Rotors for Sale Mon, 27 January 2003 05:12 Go to previous messageGo to next message
Will any of the brake setups fit my twin cam ae82??
AE82TwinCam
Canberra, ACT
Re: AE101 Levin GTZ Front and AE92 SX Rear Brakes and Rotors for Sale Mon, 27 January 2003 08:03 Go to previous messageGo to next message
The front setup will fit on with a tad bit of machining of the rotors, as for the back you will require mounting brakets for the calipers as the AE92 caliper bolt holes are slightly further apart.
You will need at least 15inch wheels to fit the ae101's on though..
-Andrew
[Updated on: Mon, 27 January 2003 08:04]
AE82TwinCam
Canberra, ACT
Re: AE101 Levin GTZ Front and AE92 SX Rear Brakes and Rotors for Sale Wed, 29 January 2003 23:25 Go to previous message
bump, I will drop the fronts to $175... I did pay 130 for the pads alone...
-Andrew
Previous Topic:4age toda billet cams
Next Topic: NEW..Adj Fuel pressure Regulator SOLD!!
Current Time: Sat Oct 24 19:02:37 UTC 2026
Total time taken to generate the page: 0.0054540634155273 seconds
