Toymods » Tech & Conversions » AE82 Twin Cam dead g/box or not???
rollaboy
Coffs
icon9.gif  AE82 Twin Cam dead g/box or not??? Thu, 23 January 2003 12:49 Go to next message
I have been putting my front super low king springs in on monday. The Banjo bolt was stripped that holds on the brake line, put a Helicoil it that.
Put car all back together this afternoon.
Went for a test drive tonite. Road was wet.
Car was going nicely till i tried on to the main road..spun in 1st then changed to 2nd still spinning so changed to 3rd and there was nothing. Slowed down, found 2nd and 4th....pulled over around the next corner.
Checked for fluid leaks.
Cable linkages look all ok.
Shifter moves up and down and a little sideways.
Its suck in 2nd second and i have no neutral.
I can move shift around with foot off clutch and theres nothing at all.
Is my g/box dead or is it something simple??
Thanks Brett
haggis
Re: AE82 Twin Cam dead g/box or not??? Thu, 23 January 2003 23:02 Go to previous messageGo to next message
Hate to say it, but that sounds exactly like a dead gearbox. Selector fork mabey.... doesnt sounds like you've stripped a gear. (did that twice last year in the rally car....)
Craig.
rollaboy
Coffs
Re: AE82 Twin Cam dead g/box or not??? Fri, 24 January 2003 13:12 Go to previous messageGo to next message
Its all good i took a closer look and worked out that the shift control cable had snapped which is why it was stuck in gear and sloppy as.
Got a second hand one for $44 and fitted that and its all good now.
But this time i went for a test drive the speedo died. What is up with my car everything breaks.
haggis
Re: AE82 Twin Cam dead g/box or not??? Tue, 28 January 2003 03:38 Go to previous message
Good to hear it was a simple fix Smile
You probably have the same problems i have.. the car is getting old!
Craig.
Previous Topic:quick 4age help
Next Topic:1j Cressida owners / Soarer Owners
Current Time: Fri Nov 20 21:51:55 UTC 2026
Total time taken to generate the page: 0.010493993759155 seconds
