Toymods » Tech & Conversions » 4AC blown head gasket?
xpimp
melbourne
4AC blown head gasket? Thu, 23 January 2003 13:09 Go to next message
I recently overheated my 4ac corolla... its been running in high temps and today i noticed that the water bubbles when the caps off Sad
I know this is REALLY bad news having done it before, so i put a pressure tester on the radiator and gave her a cranking to 110PSI (yes i know its higher but im very annoyed)... The pressure DID NOT DROP
Does this mean that the head is blown? why wont water travel back into the engine?
NOTE this is bubbling with water, havent tried coolant... would it bubble if its just normal water
[Updated on: Thu, 23 January 2003 13:10]
haggis
Re: 4AC blown head gasket? Thu, 23 January 2003 22:53 Go to previous messageGo to next message
Bubbles in the water is a classic sign on a head gasket death. Xhexk the oil as well and see if there is any water sitting on top of the oil in the sump. You might only have a leak between a cylinder and the water jacket. You would get these bubbles with water or coolant.
I've had a similar thing where i couldnt get a definate leak useing a preasure tester, but when i pulled the head off the head gasket had gone, but it was a very small leak.
A few things to check beffore whiping the head off:
- hoses. are they old and dying?
- thermostat housing, no leaks?
- leaks around the water pump
- radiator cap. This may also explaine whay it isnt pulling coolant back from the over flow bottle. (a new radiator cap and do wonders sometimes)
also, put your hand behind the exhaust and see if it gets wet quickly. This would be a good sige that water is betting pulled through the combustion chambers.
The head gasket is easy to change, I've done it in a day by myself, but the head and block didnt require any work.
Oh, and only use water to test for a leak after say putting a radiator or water pump back in. Run coolant! Running stright water for a long time will do 'bad things'(tm). Also, coolant has a higher boiling point, so is able to do its job to a higher temp.
Good luck!
Craig.
xpimp
melbourne
Re: 4AC blown head gasket? Fri, 24 January 2003 13:19 Go to previous messageGo to next message
The strange thing is no water comes out exhaust and theres definately no water in the oil :/
Would it be just boiling causing the bubbles? without a cap on theres less pressure could that cause this?
Sam
Sydney, Australia
Re: 4AC blown head gasket? Sun, 26 January 2003 17:23 Go to previous message
THe water in my radiator bubbles when the thermostat opens, and this is a new 4AGE so I'm pretty sure the head gasket is still ok (hopefully! Shocked ).
Is that the only sign you have? ie no oil in water, or water in oil? Maybe your radiator's blocked and needs a good flushing or something...
rgrds
sam
Previous Topic:Corona Conversion Crap
Next Topic:4age rebuild
Current Time: Tue Oct 13 14:57:50 UTC 2026
Total time taken to generate the page: 0.026782989501953 seconds
