Toymods » General Car Talk » What every 1JZ owner should get done! [Warning Large Pics]
wastegate
Gold Coast
What every 1JZ owner should get done! [Warning Large Pics] Sat, 25 January 2003 09:29 Go to next message
Thanks to Celicamads website for this.
Well after putting my 1JZGTE into my car I sent it off to get the Exhaust done and found out that I have a stuffed turbo.. so off they come to get replaced under warrenty so I thought I would show you lot what a proper exhaust shop can do!
BTW the business was Exotic Exhaust in Brisbane.
http://jzgte.com/~nickc/images/mycar/1JZSwap/shotturbos/2/images/DSC00004.jpg
http://jzgte.com/~nickc/images/mycar/1JZSwap/shotturbos/2/images/DSC00020.jpg
More photos here
http://jzgte.com/~nickc/images/mycar/forum_sig.jpg
Performance Forums
87seca
Goulburn
Re: What every 1JZ owner should get done! [Warning Large Pics] Sat, 25 January 2003 10:08 Go to previous messageGo to next message
thats some nice work there.... what did that set you back?
Ollygt
Re: What every 1JZ owner should get done! [Warning Large Pics] Sat, 25 January 2003 10:18 Go to previous messageGo to next message
Ahh yes Celicamads famous twin pipes replacement of the Y piece Smile
A must do mod.
thunderbird1
Sydney Australia
Re: What every 1JZ owner should get done! [Warning Large Pics] Sat, 25 January 2003 12:18 Go to previous messageGo to next message
very nice... definatly my next thing to do! i just wish i had backed off the studs and put bolts in when i had the turbos off a few weeks ago!! damn! Anyhow, only takes me and a mate 45 minutes to have my turbos off the motor so its not too much extra.
Luke
Soarer
Wollongong
Re: What every 1JZ owner should get done! [Warning Large Pics] Sun, 26 January 2003 00:45 Go to previous messageGo to next message
How much ? How much ? How much ? How much ? How much ? How much ? How much ? How much ? How much ? How much ? How much ? How much ? How much ? How much ? How much ? How much ? How much ?
Razz
Those pipes look awesome... very well made.
I like the shot of them un-installed.
Do they come out to a 3" flange ? Cos the rest of my exhaust is 3" mandrel system. Would be nice to finish it off and put this in front of it all.
Bugman
Re: What every 1JZ owner should get done! [Warning Large Pics] Sun, 26 January 2003 02:32 Go to previous messageGo to next message
just curious how's the exhaust sensor gunna go only being in the flow of half the motor? not that i have an idea of how they work... so I'm not claiming to be an expert, just something I noticed.
wastegate
Gold Coast
Re: What every 1JZ owner should get done! [Warning Large Pics] Sun, 26 January 2003 06:57 Go to previous messageGo to next message
And the cost is $600, bit of money but I think it's worth it. Yeah joins up to a 3" pipe.
Soarer
Wollongong
Re: What every 1JZ owner should get done! [Warning Large Pics] Sun, 26 January 2003 10:53 Go to previous messageGo to next message
Bugman, the oxygen sensor will still work as normal, because it just measures the ratio of air/fuel. It won't make any difference only measuring from one pipe, as the ratio would be the same for both dump pipes.
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: What every 1JZ owner should get done! [Warning Large Pics] Mon, 27 January 2003 01:25 Go to previous messageGo to next message
You hope the A/F ratios are the same for both dump pipes, but in many circumstances this may not be the case. Serious race engines use exhaust gas temperature to determin A/F ratios (more accurate or something), & will have 1 sensor per cylinder. It is very possible for 1 or only a couple of cylinders to terminally lean out.
For example, I've heard that with WRXs, with their 2 fuel rails, that with a bit of work & with the injectors really working hard, the 4th cylinder can lean out 'cos there's just not enough fuel making it to the 4th injector. WRX go bang now.
I'm nor saying it's heaps bad or anything, I've seen/heard of plenty of people doing it, it's just that you can have different A/F ratios for different cylinders, & this may cause probs. The other solution is 2 O2 sensors, or a heated sensor mounted further down where the 2 go into 1.
Guest
Re: What every 1JZ owner should get done! [Warning Large Pics] Mon, 27 January 2003 02:28 Go to previous message
The O2 sensor on the 1j, as in most modern efi engines is only used to control A/F ratios in closed loop operation, ie. at idle or constant low load cruising.
so to only be testing one pipe from the engine would be accurate enough for these low risk conditions.
My twin pipes have only one sensor as well. If I wasnt conserned about fuel consumption I wouldn't use it at all!!
Matt
Previous Topic:What Toyota manual is this?
Next Topic:Colour for 1981 Celica XX (Mk2 Supra)
Current Time: Sat Oct 31 21:51:08 UTC 2026
Total time taken to generate the page: 0.0052268505096436 seconds
