Toymods » Tech & Conversions » Inlet Manifold?
sebta22
Inlet Manifold? Sat, 25 January 2003 15:01 Go to next message
I am putting a 4AGTE RWD engine together from 4agze FWD engine. I am planning to use the 4AGZE head (I think engine is Mk 2 or 3)so it seems the head is small port. From what i understand the the only bolt on manifold is the the RWD 4age 86kW. Is this true and is there any alternative? What principals are to be used on making an inlet manifold?
Re: Inlet Manifold? Sat, 25 January 2003 21:48 Go to previous messageGo to next message
Depends if you've got a small or big port head. The RWD manifold will only work with a big port head - sure it'll bolt onto a small port head, but won't work too well Very Happy
Your alternative is to either make something from scratch (which is what I'd do because I love that kinda thing!), or get a small port 4AGE manifold 'turned round'. I've got one of these lying round that I had done for my engine before it broke (the engine), and I ended up with a big port head.
sebta22
Re: Inlet Manifold? Sun, 26 January 2003 02:56 Go to previous messageGo to next message
How do you find out if the head is small or large port? Is there dimension on the width of the port?
How did you make your inlet manifold? Did you simple weld small diameter pipes to a large diameter pipe or is there some rules to follow?? cheers Very Happy
rollaboy
Coffs
Re: Inlet Manifold? Mon, 27 January 2003 05:48 Go to previous message
Have a look at this page (from Bills Website) for info on the differences in the big port and small port head.
http://www.billzilla.org/4agstock.htm#head
Previous Topic:removing locknuts, wtihout key
Next Topic:Leaking ball joint
Current Time: Fri Oct 23 01:06:26 UTC 2026
Total time taken to generate the page: 0.0048251152038574 seconds
