Toymods » Tech & Conversions » 4AC probs
RobertoX
icon9.gif  4AC probs Mon, 27 January 2003 04:20 Go to next message
my 4AC is running really bad (not that it ever ran good as such).
It starts and idles normally for a few seconds and then the revs slowly drop till it dies. It Starts ok every time and if i rev it its ok but stopping at traffic lights is rather an annoyance!
Any Ideas on where to start looking? Does this problem sound farmiliar?
Cheers for any help...
Bugman
Re: 4AC probs Mon, 27 January 2003 04:26 Go to previous messageGo to next message
try adjusting you idle screw in the carby.
FLY PSI
icon4.gif  Re: 4AC probs Mon, 27 January 2003 06:22 Go to previous messageGo to next message
I had a problem that was sounds just like that! I eventualy found that the auto chock was playing up. as i had a spare carby i just swap them over and it hasnt done it! Smile
Hunty
Re: 4AC probs Mon, 27 January 2003 06:44 Go to previous messageGo to next message
maybe a vacuum leak, check the PCV valve, tho that would usually make quite a loud hissing sound hmm worth a shot
RobertoX
Re: 4AC probs Mon, 27 January 2003 06:48 Go to previous messageGo to next message
Yeah, I already adjusted the idle control to so now it idles at about 2k... kinda helps but not that much...
will check out the choke as I have had problems with it recently, haven't really had too much time to play with it a lot yet, just want a few ideas as to where to start.
thanks guys
any other suggestions would be greatly appreciated also
[Updated on: Mon, 27 January 2003 06:49]
AE86
Face down in a ditch
Re: 4AC probs Mon, 27 January 2003 09:45 Go to previous messageGo to next message
Also check that the leads are properly secured.
Sam
Sydney, Australia
Re: 4AC probs Mon, 27 January 2003 19:46 Go to previous messageGo to next message
you could also try checking for air leaks around the carby, maybe a vacuum hose has popped off somewhere or maybe the gasket is leaking.. just a thought...
rgrds
sam
BillusMcFlunday
Re: 4AC probs Wed, 29 January 2003 00:25 Go to previous message
I have had a simmalar problem just recently mine was a combo of the auto choke and the timing, i have since got the timing belt replaced. just a tip, if you want the 4ac to go harder... advance the timing til it pings nock it back a few degrees and bingo you have yourself a pocket rocket that should by rights knock off most standard ae92's he he he...
I'm not sure how long that will make the engine last tho. not that i care i'm putting in a 7A-FC!! (7A-FE block and 4A-FC head)
Billus McFlunday
Previous Topic:rt132 Struts - worth buying for upgrade?
Next Topic:how powerfull is your 4agte
Current Time: Fri Nov 20 20:56:29 UTC 2026
Total time taken to generate the page: 0.0042529106140137 seconds
