Toymods » Tech & Conversions » 18R-C Inlet Upgrade
simulant
Sydney - Northern Beaches
18R-C Inlet Upgrade Mon, 27 January 2003 05:16 Go to next message
Any one know a cheap and easy way to upgrade the inlet on an 18R-C, it's so bloody restrictive, I was thinking if nothing else to just trying to jack the carbie up a bit on a spacer block, to perhaps give it a bit extra torque.
Is there easily bolted on carbie/manifolds that will have better flow??
Alan.
Jason
Re: 18R-C Inlet Upgrade Mon, 27 January 2003 05:42 Go to previous messageGo to next message
You could start with a new engine. Very Happy
I know what you mean about the inlet manifold though. Other than making a custom manifold i dont know how you could fix the problem I mean lets face it the volume metric effeciency of the engine isnt really high so you might just have to put up with it. If youve got a standard carby you could just oversize the primary jet on size i did this and it had a noticable difference.
[Updated on: Mon, 27 January 2003 06:09]
simulant
Re: 18R-C Inlet Upgrade Tue, 28 January 2003 08:48 Go to previous messageGo to next message
Well, I was trying to get my hands on an 18r-g, but unfortunatly, the 18r-c had a bit of a failure and had to spen cash on it just to keep the thing running, so it'll have to wait till another day I guess.
Thanks anyway
Al
M.W.P.
Rocky Mountains, Canada
Re: 18R-C Inlet Upgrade Wed, 29 January 2003 06:48 Go to previous messageGo to next message
You could try and get a 18R inlet manifold.
Nicer than the 18RC... doesnt have the emissions stuff connected to it everywhere. Very simple.
Jason
Re: 18R-C Inlet Upgrade Wed, 29 January 2003 22:11 Go to previous messageGo to next message
i didnt think of that i have one of those but it still has that right angle bend straight after thw carby.
M.W.P.
Re: 18R-C Inlet Upgrade Thu, 30 January 2003 08:44 Go to previous messageGo to next message
Jason wrote on Thu, 30 January 2003 08:41
That it does Sad
I wonder how difficult it is to weld...
Grind/cut out the bend and weld in a bigger turn area box.
BTW... the heat box, where the inlet and exst manifolds bolt together.
How do they join... i mean, are the mating sufaces flat, or somthing else like a passage for exst gas to move into a chamber in the inlet mainfold?
GIN51E
Berowra-Sydney
Re: 18R-C Inlet Upgrade Thu, 30 January 2003 09:37 Go to previous messageGo to next message
Get a weber, ring up pick'n payless in Sydney and see if they have an inlet manifold and double throat 45mm side draft webers. they should have them if they haven't already sold them.
how do i know?
they were off my car and my car is out there Sad
simulant
Re: 18R-C Inlet Upgrade Thu, 30 January 2003 11:21 Go to previous messageGo to next message
M.W.P. wrote on Thu, 30 January 2003 19:44
they have a flat mating surface with a heat chamber inside, I belive this chamber has to do with the auto choke, theres a tube that runs down from the choke into and out of this chamber and then into the manifold I think. So the chamber heats up and I guess in turn heats the air in the tube and alters the amount of presure in the tube and changes the choke position. However if you have extractors as in my car this tube simply hangs below the manifold doing nothing.
Al
M.W.P.
Re: 18R-C Inlet Upgrade Fri, 31 January 2003 05:50 Go to previous messageGo to next message
simulant wrote on Thu, 30 January 2003 21:51
Thanks... my carb is manual choke so the three tube connections down there (incl PCV inlet) are blocked up.
Im just wondering how much of an effect it would have if i separated the exst manifold from the inlet manifold. It would keep the inlet manifold cooler, but im wondering how this would effect fuel atomization as thats partly what the heatbox is there to help with.
http://www.overclockers.com.au/~mwp/pics/car/MVC-018F.JPG
[Updated on: Fri, 31 January 2003 06:15]
Jason
Re: 18R-C Inlet Upgrade Sat, 01 February 2003 03:01 Go to previous messageGo to next message
The exh manifold has a dirty great hole there so the gases can get right up under the intake manifold. To seperate the manifolds you would have to seal up the exh which would rerquire grinding sufficient material off the manifold to fit a plate in.
That sounds like a lok of work to me the other option for you is to get a set of extractors which would improve your performance anyhows.
M.W.P.
Re: 18R-C Inlet Upgrade Sun, 02 February 2003 14:24 Go to previous messageGo to next message
Ahh right, thanks.
Thats what i was wondering... if there was a passage between the two manifolds.
I was lined up to get extractors, but that fell through Sad
I wonder if extractors would really be worth the effort anyway.
Jason
Re: 18R-C Inlet Upgrade Sun, 02 February 2003 22:26 Go to previous messageGo to next message
i USE TO HAVE EXTRACTORS ON MINE AND THEY DID MAKE A NOTICABLE DIFFERENCE TO THE STANDARD MANIFOLD
simulant
Re: 18R-C Inlet Upgrade Mon, 03 February 2003 11:30 Go to previous messageGo to next message
yeah, extracters do help, and it's a pritty easy mod, mine are pritty crap extracters but there still better than the standard manifold.
M.W.P.
Re: 18R-C Inlet Upgrade Mon, 03 February 2003 12:46 Go to previous message
Hmmm... might have to look into finding some then.
Thanks.
Previous Topic:RA 23 engine up grade options??
Next Topic:4AGE tuning problems. Help needed
Current Time: Sun Nov 22 23:08:22 UTC 2026
Total time taken to generate the page: 0.0067169666290283 seconds
