Toymods » Tech & Conversions » Compression readings in an 18R-C
munki
Gold Coast
Compression readings in an 18R-C Tue, 28 January 2003 09:39 Go to next message
Hi
Today i was driving arround and the temp has been going crazy, Im pretty sure that i have a jammed thermostat, anyway because the engine has been running quite hot and it is old, I thought i should check the compression for a possible blown head gasket, im not losing any water but better be safe than sorry.
Anyway what i want to ask is what is the normal compression reading on an 18R-C engine
Daniel
Fat_KE70
Shepparton
Re: Compression readings in an 18R-C Tue, 28 January 2003 10:03 Go to previous message
well as a rule they should all be within cooee of each other possibly about 165 - 175 psi depending on age of motor(which you say is old) and static compression eg.9 to 1 if it is a blow between(blown between 2 cylinders there will be two that are alot lower than the others, blown to a water jacket or oil gallery will give 1 low cylinder but with other symptoms like losing water and overheating or milky oil. if all are low it will most likely be rings worn and a rebuild will be best.
I have tested some engines where 90 psi was the best reading on all six pots(was a holden 202) Cool
Has the gauge been skyrocketing as well as the engine being physically hot or have you got a problem with the sender wire shorting to ground?. silly question i know but i have seen rebuilds done for things as simple as that.
Happy Hunting
Pete
Previous Topic:1jz-gte Octane requirements.
Next Topic:4agte cooling
Current Time: Fri Nov 20 20:01:53 UTC 2026
Total time taken to generate the page: 0.0052270889282227 seconds
