Toymods » Tech & Conversions » 4AC Head Change Over Cost?!
Necros
4AC Head Change Over Cost?! Wed, 29 January 2003 03:39 Go to next message
Hey Guys,
Whats a reasonable price to get a 4AC head swapped over, and what sort of gaskets would I need?
I was just quoted a price of ~$300ish for a head change over, thats a bit harsh aint it?
Luke aka Necros
EvilJack
Sutho/Hills NSW
Re: 4AC Head Change Over Cost?! Wed, 29 January 2003 04:34 Go to previous messageGo to next message
your lucky
reco heads go for around 1k
or am i getn bum steered Razz
my brother just had his done.
haggis
Re: 4AC Head Change Over Cost?! Wed, 29 January 2003 05:21 Go to previous messageGo to next message
Seeing as i just picked up a 4A-C, running, no smoke, good condition, for $50, including an Exeddy clutch plate, its almost not worth getting a head done on a 4A-C.
Having said that, it does depend on whats been done to the head. Just a clean and check? has it been decked? ported? Has it been converted for unleaded use? etc. Are you doing this yourself, or paying to get it done? Find out the details before making a decision, this may well tell you if it's a good price or not.
EvilJack: if its a fully reco head, with new valves etc, yes, it could go to that depending on the engine you are talking about. A reco 4A-C was quoted to me at $1300. For $1600 you can a GZE import!
Head gaskets start at about $40 from a Gas Miser, but for reliability, you want one around the $60 to $70 mark. Manifold gasket (just one cause its not a x-flow head) are under $20 The rocker cover gasket should be reuasable, other wise there $15 aprox.
Don't for get the labour for swapping over vales or needing new ones for the new head. Either way it will cost you to get it done, or you may need special tools to do it yourself if you dont already have them.
Just out of curiosity, whats wrong with the old head that made you need to get a new one?
So with out more details, yes, $300 could well be the right price.
Craig.
Necros
Re: 4AC Head Change Over Cost?! Wed, 29 January 2003 11:51 Go to previous messageGo to next message
The current head on the engine is cracked, so I need to get the good head I have put on it Razz
MaNGeW
Formerly TRD_RoLLa
Re: 4AC Head Change Over Cost?! Wed, 29 January 2003 12:01 Go to previous messageGo to next message
$300 is reasonable for a reco'd head swap over.
Im actually in the progress of getting the cylinder head off my sister's laser. Since it overheated and had a blown head-gasket.
Im getting mine re-surfaced, cleaned up for ~$155 incl. GST. They pretty much clean it all. Valves and intake/exhaust ports. THey pressure test it too and check for cracks. I actually have to drop it to them at 8am in the morning. Rolling Eyes
(damn no sleep in).
I then need to buy some gaskets (just like Haggis mentioned)
oil filter, oil, etc etc.
The block seems ok, just need a bit of a clean with some very light sanding. To get the surface rust out of the piston bores.
I sorta wasted half a day today coz I went and bought a replacement cylinder head from a wrecker only to find when i got home Sad that one of the valves were bent (not happy jan)
So therefore just goin to return this head and use the existing head off the car to be milled.
Hope it all goes well.
Oops just saw u said ure head is cracked.
Just get the another recoed cylinder head.
[Updated on: Thu, 30 January 2003 12:49]
Necros
Re: 4AC Head Change Over Cost?! Tue, 04 February 2003 00:05 Go to previous message
Well being stubborn as I always am ;p I decided that I would rather keep my $300 and spend my days off doing the head swap myself Smile
10~ Hours work and some mashed fingers and I got the job done! Ive never done one before so there was a bit of a learning curve!
The only problems I encountered was:
* Setting the timing, had to learn that too...
* Putting the damn spark plug leads on in the wrong order ;p
* Loosing one bolt after everything was working! And it was from the damn bonnet hinge of all things!
And in the end all it cost was $90 for gasket set, $35 for an oil filter and 6lt of oil and $30 for a 2nd hand head that had been smoothed on the bottom!
Damn thing runs better than ever now! Nice and tail happy on gravel roads again...
Previous Topic:is a 7mgte head o-ringed?
Next Topic:Dust cover between gear box and propeller shaft
Current Time: Sun Nov 22 23:30:21 UTC 2026
Total time taken to generate the page: 0.34900093078613 seconds
