Toymods » Tech & Conversions » 1986 AE82 twin cam diagnostics plug???
Jonoze
1986 AE82 twin cam diagnostics plug??? Wed, 29 January 2003 03:47 Go to next message
Hey all,
Where is the diagnostics plug on an 1986 ae82 twin cam???
I want to check the timing and you have to connect two of the diagnostic pins.
Thanks for your help.
Jono.
MaNGeW
Formerly TRD_RoLLa
Re: 1986 AE82 twin cam diagnostics plug??? Wed, 29 January 2003 12:06 Go to previous messageGo to next message
Its the yellow plug located near the front windscreen wiper motor. It has 2 wedge female connections. Jump the connection with anything that conducts and presto.
Your engine check light should now be on/flashing.
timing is 10deg. BTDC as u prob know Smile
Rowan
Re: 1986 AE82 twin cam diagnostics plug??? Thu, 30 January 2003 08:47 Go to previous messageGo to next message
hehe. it took me so so long to work that out when i got my first twincam! i understand the pain...
rollaboy
Coffs
Re: 1986 AE82 twin cam diagnostics plug??? Thu, 30 January 2003 12:11 Go to previous messageGo to next message
Heres a photo that might help you.
http://www.plusoneinteractive.com/rollaboy/diagnostics%20plug
Jonoze
Re: 1986 AE82 twin cam diagnostics plug??? Thu, 30 January 2003 21:05 Go to previous messageGo to next message
Thanks for the replies.
I thought it was the round two pin yellow plug in the left of the photo.
Cheers.
MaNGeW
Formerly TRD_RoLLa
Re: 1986 AE82 twin cam diagnostics plug??? Fri, 31 January 2003 06:11 Go to previous messageGo to next message
yeh its the round one
rollaboy
Coffs
Re: 1986 AE82 twin cam diagnostics plug??? Sat, 01 February 2003 03:27 Go to previous messageGo to next message
Well i didnt draw that pic. Was on my computer somewhere.
4AGE
Re: 1986 AE82 twin cam diagnostics plug??? Mon, 28 February 2005 06:13 Go to previous messageGo to next message
I know this is an old thread.
Can someone tell me which connector there is.
There is 3 i have doubts with
Round plug 2 vertical slots? Rubber cover?
Round plug with plastic cover
I heard this is the wrong one but squarish 1 vertical 1 horizontal.
Maybe a photo or drawing to show?
4AGE
Re: 1986 AE82 twin cam diagnostics plug??? Tue, 01 March 2005 00:08 Go to previous messageGo to next message
I found that connector.
What does that connector do anyway. check light comes on in 10 blink intervals. supposedly .26 seconds.
Any help would be good.
towe_001
Somewhere on a dirt bowl ...
Re: 1986 AE82 twin cam diagnostics plug??? Wed, 02 March 2005 12:48 Go to previous messageGo to next message
Its used for diagnosing faults etc. A manual like a Haynes will say what all the flashes mean
4AGE
Re: 1986 AE82 twin cam diagnostics plug??? Fri, 11 March 2005 08:17 Go to previous messageGo to next message
That i realise. But crossing crossing the connector whilst doing the timing light? What is the actual result of it? Or is it a precautionary thing? Because i crossed the terminals and sweet jack all happened.
towe_001
Re: 1986 AE82 twin cam diagnostics plug??? Fri, 11 March 2005 10:50 Go to previous messageGo to next message
I"m not really sure what the go with doing it is, about the only info that i've found so far is that dueing normal idling the timing sits anywhere between 5 deg and 15 deg and by fitting a lump of wire (or SST 09843-whatever) stops the timing from moving around. But i've always just gone for the old style, hook the timing light to Cyl. #1 and to the battery and then use the "looks good, is good" theory. Cause the bloody hose is in the road Mad
Buts about all i can find on as to why...
4AGE
Re: 1986 AE82 twin cam diagnostics plug??? Fri, 11 March 2005 22:55 Go to previous messageGo to next message
My timing doesn't jump around on idle at operating dtemperature. NOTHING happens when i cross it. Ah well. That means its normal then Very Happy
FKN16V
NSW, East Coast
Re: 1986 AE82 twin cam diagnostics plug??? Fri, 11 March 2005 23:31 Go to previous message
4AGE wrote on Sat, 12 March 2005 09:55
Well not really, if there is a problem with the wiring(sensor dies or there is any other form of abnormallity) the ecu record this data and usually if its bad enough will go into limp home mode. when shorted the idle should drop a little and if you check the timing before you should have 15-18 deg btdc, shorten connector and it should drop to 10-12deg btdc
Shorting the connector tells the ecu to tell you what codes are present, thru the flashes of the check engine light.
http://www.toymods.org.au/Repository/index.php?dir =4age_book/efi
You read and you will learn.
fwiw 10 flashes means nothing is wrong
Steve
[Updated on: Fri, 11 March 2005 23:32]
Previous Topic:4AGZE into KE55
Next Topic:cams?? 2tg
Current Time: Fri Nov 20 04:11:41 UTC 2026
Total time taken to generate the page: 0.0056211948394775 seconds
