Toymods » Tech & Conversions » is a 7mgte head o-ringed?
Heyah
is a 7mgte head o-ringed? Wed, 29 January 2003 11:52 Go to next message
i recently removed the head of my 7m , and noticed that the head is o-ringed not the block is this standard ?
if not why would the head b done and not the block?
also what tests should b carried out on tha head ? ( for leaking head gasket area specifaclly) before i put it back on?
ROBBO_ma61
Re: is a 7mgte head o-ringed? Wed, 29 January 2003 11:57 Go to previous messageGo to next message
people o ring the heads to try and stop the bhg problem. Test it for cracks and also look for any signs of how it could be warped. Block doesnt need to be o ringed as far as i know. not 100% sure tho.
Re: is a 7mgte head o-ringed? Wed, 29 January 2003 13:36 Go to previous messageGo to next message
7M's are definitely not o-ringed from the factory. If yours has an o-ringed head, it's been modified by someone at some point.
SUPRAGTE
North Sydney
Re: is a 7mgte head o-ringed? Thu, 30 January 2003 08:53 Go to previous messageGo to next message
You lucky bastard, if my 7mgte head was oringed i'd run more than 14psi(currently 420hp) and throw 20psi into it and crack the 500hp mark Shocked Shocked
Got any pics of it??
Heyah
Re: is a 7mgte head o-ringed? Thu, 30 January 2003 10:39 Go to previous messageGo to next message
i might do i took some pics with my mates dig camera over the course of rebuild so i might have one..
i do have a pic of my head gasket though i cant work out how to get it up here.... ( im no a comp friendly kinda guy)
ill find out and post some if i do!
is it likely that the head would b cracked? im sort of leaning towards this as a cause to my dramas at the moment.
what mods are good for a 7m head while there of as it looks like it mihgt b comming of again! Sad
1ndecent
Re: is a 7mgte head o-ringed? Fri, 31 January 2003 19:11 Go to previous messageGo to next message
Stock heads are not O-ringed. What kind of gasket was it using, and how tight were headbolts?
Heyah
Re: is a 7mgte head o-ringed? Sun, 02 February 2003 04:26 Go to previous messageGo to next message
they were using a copper head gasket about 1mm , orginal bolts and i dont know how tight, but they were torqued over spec , so id say about 70Nm
they were all tight when i took them off
SUPRAGTE
North Sydney
Re: is a 7mgte head o-ringed? Mon, 03 February 2003 07:48 Go to previous messageGo to next message
Definitely been modded then. Some pics would be really good!
You could email them to me and i could post them up.
paul.pearce@honeywell.com
Heyah
Re: is a 7mgte head o-ringed? Tue, 04 February 2003 01:29 Go to previous messageGo to next message
big dramas! head apears to b leaking as it was before...
talking to eng reco mob who said it is a very bad idea to oring a alloy head , the head is to soft and the orings push up into the head, and when torquing them down they will tend to sqew the head. so it looks like im up foor a new head!Mad
anyone have one worth seling? Smile
( im still trying to get my photos!)
ed_ma61
Lost in the K hole
Re: is a 7mgte head o-ringed? Tue, 04 February 2003 01:59 Go to previous message
yep... i have a spare 7m head. no cams, but otherwise complete (valves, springs, buckets, shims etc) bearings are in v good nick with minimal scoring. havent looked at the valve seats or anything, but it came off a running engine. you could chose to do a valve job on it if you wanted to.
water jackets are in v good condition, w/ minimal erosion.
$80?
where abouts are you located?
ed
[Updated on: Tue, 04 February 2003 02:02]
Previous Topic:Mazda MX6 Seats in a RA23 or TA22?
Next Topic:4AC Head Change Over Cost?!
Current Time: Sat Nov 21 04:22:12 UTC 2026
Total time taken to generate the page: 0.005713939666748 seconds
