Toymods » Tech & Conversions » 1ggte wiring! what am i doing wrong (i heard traction issues knows a fair bit)
CrAiGzEE
south of the big smoke
1ggte wiring! what am i doing wrong (i heard traction issues knows a fair bit) Wed, 29 January 2003 23:51 Go to next message
atm it aint doing anything, besides turning over
ok guys i have wired it as the diagram says what have i missed?
ecu input
1= batt i have it coming from the battery into a 20amp fuse then to main efi relay (connector 2 on relay) and batt on ecu
2. to ignition switch via a 7.5amp fuse
11. to starter via a 7.5amp fuse
4. to connector 1 on the main efi relay
5. going to globe on dash with power on the other end
16. to turbo indicator light
relays
Main efi relay
one and two i have mention already
3. to earth
4. into connector 2 of circuit open relayand to 1(f1)
circuit open relay
1. to fuel pump
2. already mentioned
3. into starter
4. to 15(F1)
6. earth
thats about it i think
all help would be great , also i heard that the ns/w has to be wired into the circuit open relay but i have been lead to believe it is wired to the starter??
tar
[Updated on: Wed, 29 January 2003 23:55]
gold28
Madrid - Spain
Re: 1ggte wiring! what am i doing wrong (i heard traction issues knows a fair bit) Fri, 31 January 2003 05:29 Go to previous messageGo to next message
Check that you have power to your ecu and ignitor/coil and make sure that you are getting fuel to the injectors. If this all checks out, have a close look at all connections for your ignition circuit. Other than that it is a bit had to tell without seeing it.... sorry
CrAiGzEE
Re: 1ggte wiring! what am i doing wrong (i heard traction issues knows a fair bit) Sat, 01 February 2003 02:32 Go to previous messageGo to next message
yeah i think i have worked out my problem! i dont think the comnputer is getting power from the ignition
ill have a look today
CrAiGzEE
Re: 1ggte wiring! what am i doing wrong (i heard traction issues knows a fair bit) Sat, 01 February 2003 03:03 Go to previous message
gave ignition power to the ecu and now it turns over by the ig
grrr
Previous Topic:1ggte overfueling
Next Topic:heart attack after 18rgu piston prices
Current Time: Fri Nov 20 12:51:01 UTC 2026
Total time taken to generate the page: 0.0050928592681885 seconds
