Toymods » Tech & Conversions » where can i get cam gears for 4age, and also cams in syd...
barbel
where can i get cam gears for 4age, and also cams in syd... Sun, 09 June 2002 06:00 Go to next message
any know of any shops where they have had good experience with,
want some cams for my 4age and also cam gears,
Darola
Taree, 4h nth of syd
Re: where can i get cam gears for 4age, and also cams in syd... Tue, 11 June 2002 08:47 Go to previous messageGo to next message
yes can get, will need to ship over, what grind and type of gears ie. vernier/fixed ect
can get anything u want and need
barbel
Re: where can i get cam gears for 4age, and also cams in syd... Tue, 11 June 2002 09:55 Go to previous messageGo to next message
was thinking vernier cam gears and cams prob as much lift and duration as can go with standard shim setup, have programmable ecu. prob 288 degree.
where do you get them from?
Darola
Re: where can i get cam gears for 4age, and also cams in syd... Tue, 11 June 2002 10:20 Go to previous messageGo to next message
can get abit more go with standed shims, if u want to go wild u will have to change shims
if no change of shims, lucky to get extra 20hp depending on other mods, if change shims can up to extra 50hp
can get cams from nz
barbel
Re: where can i get cam gears for 4age, and also cams in syd... Tue, 11 June 2002 11:25 Go to previous messageGo to next message
it's been recently rebuilt, ported head, new valves and springs, shaved head, new rings and bearings bottom end,
how much is shim under, was thinking to keep cheap as possible, budget for cams and gears...
Darola
Re: where can i get cam gears for 4age, and also cams in syd... Tue, 11 June 2002 11:52 Go to previous messageGo to next message
ok, $400 a cam whatever spec u want, and $35 a shim (normal), or trd hi rev shims $120 each
ring my friend now and he will explain everything for u, his name is corry #0402376020
barbel
Re: where can i get cam gears for 4age, and also cams in syd... Wed, 12 June 2002 00:01 Go to previous messageGo to next message
so is that $400 bux each cam??
what about cam gears? and whats the difference between the normal shims and trd shims?
looking for prices right now, not ready to buy just yet,
purpleminiep
Mentone
Re: where can i get cam gears for 4age, and also cams in syd... Wed, 12 June 2002 01:19 Go to previous messageGo to next message
If you are looking to change your shims to TRD style you could give this guy a try http://www.precisionshims.com.au/. I emailed him and he was very helpful. He is mostly motorbike but remember Yamaha has a big say in most toyota heads anway. HE said he could make something work.
Precision Shims Australia
RETAIL PRICE LIST
7.0[cups] 1.20 2.40 $7.50 $8.25 ea.
7.5 1.40 3.50 $5.46 $6.01 ea.
9.5 1.40 3.50 $8.10 $8.91 ea.
13.0 2.00 3.20 $6.05 $6.66 ea.
25.0 1.40 3.50 $7.70 $8.47 ea.
29.0 1.40 3.50 $11.25 $12.38 ea.
29.5 1.40 3.50 $9.02 $9.92 ea.
Dia.mm from.mm to.mm prices inc gst
Shims increase in thickness by 0.05mm STEPS
Other diameters and thicknesses made to order on request
Postage and handling $6.60 or overnight $8.80 inc gst per order Anywhere in Australia
PAYMENTS CHEQUE, CASH, COD, MONEY ORDER.
Darola
Re: where can i get cam gears for 4age, and also cams in syd... Wed, 12 June 2002 06:54 Go to previous messageGo to next message
yes thats 400 per cam, still pricing cam gears.
normal toyota shims sit on top of bucket, trd shim and bucket sets, shims sit under buckets witch allows higher rpm due to shims cant fly out, recommend trd valve springs (gauranteed 10,000 rpm with this set up)
barbel
Re: where can i get cam gears for 4age, and also cams in syd... Wed, 12 June 2002 06:58 Go to previous messageGo to next message
i think i'l leave my standard shims for now, can't justify 2k for shim under when i can put it toward turbocharging the engine and make more power easily.
was thinking cams and gears only for now
also, what kind of cams would you put in it?
i'm thinkin either 288 or maybe 304 degree...
[Updated on: Wed, 12 June 2002 07:04]
Darola
Re: where can i get cam gears for 4age, and also cams in syd... Wed, 12 June 2002 07:11 Go to previous messageGo to next message
depending on the grind severity of the cams you will need to change the shims anyway , if you just want a mild increase i can get cams ground to match your original shim settings , any more than about a 20% increase in lift and duration will mean you need to reset the shim thicknesses to suit the new profile , adjustable vernier cam pulleys , can do for around $300 each with max 40 degree adjustment using original gear sets (i have) , hope this helps , any other questions please dont hesitate to ring me on mobile 0402376020
1bam777
Perth WA
Re: Vernier Cam Gears Fri, 14 June 2002 16:18 Go to previous message
Vernier cam gears can be bought from most import performance speed shops. I'd recommend either HKS or TODA units. Very good, clear markings on the cam wheels, and easier to dial in. HKS ones should be available for about A$560 or less a pair.
If you have a programmable ECU and are thinking of turbocharging later, a set of 288 duration cams and about 8.3mm of lift should be nice. Bigger cams will have too much overlap for a turbo setup (for street use). If you have a set of quad throttle bodies and are thinking of staying NA, then go bigger...
[Updated on: Fri, 14 June 2002 16:21]
Previous Topic:Anyone done a 4agze into a ke10?
Next Topic:4AC -> 4AGE/GZE?
Current Time: Sun Oct 18 02:15:26 UTC 2026
Total time taken to generate the page: 0.0058498382568359 seconds
