Toymods » Tech & Conversions » Calling all mechanics....how to remove Camry drive axles from transaxle??
raptorsc
Mackay
icon9.gif  Calling all mechanics....how to remove Camry drive axles from transaxle?? Sun, 02 February 2003 09:28 Go to next message
Fellow mechs
How much force does it take to extract the short shaft on lefthand side of transaxle, the one once actually goes into the diff itself. The other end of the shaft bolts directly to the CV joint on end of drive shaft.
So far I have been unable to lever it out or jerk it out by hand, should I be using a slide hammer??
Am I trying to do it all wrong??
Confused
raptorsc
Mackay
Re: Calling all mechanics....how to remove Camry drive axles from transaxle?? Thu, 06 February 2003 03:05 Go to previous messageGo to next message
Hmmmmm
I must be a pioneer with this little job. Don't really want to take it to a Tojo service center for this little task. I am actually wanting to reshim the tapered roller bearing on the differential carrier.
Surely someone knows something about what normally happens with a task like this???????????????????/ Confused
FWDCelica
sydney,nsw.oz.
icon14.gif  Re: Calling all mechanics....how to remove Camry drive axles from transaxle?? Thu, 06 February 2003 21:17 Go to previous messageGo to next message
Try the Sharp end of a Tyre leaver. (the end you use to take hubcaps off). It has worked for me before.
In fact you might need 2 of them, 1 either side.
Remeber to drain the Gearbox before you take it out. Very messy otherwise!
Good Luck !
T.
[mikey]
Re: Calling all mechanics....how to remove Camry drive axles from transaxle?? Thu, 06 February 2003 23:19 Go to previous messageGo to next message
I generally use a piece of wood against the inner cv and a big hammer on the end of the wood, the idea is that it forces the C clip inside down and through the groove where it will come out easily. It doesnt take too much to knock one out, its actually quite easy if u do it right, dont attack the cv with a hammer incase you damage it.
raptorsc
Mackay
Re: Calling all mechanics....how to remove Camry drive axles from transaxle?? Sat, 08 February 2003 11:21 Go to previous message
Many thanks for the input.
I also approached the foreman of the workshop at local Toyo dealership. He recommended to not bother with reshimming the differential carrier bearing, as he said nearly all of them are sloppy and it makes no difference to their operation.
So it will stay as it is since the man said its quite acceptable!!
Hope this is helpful to a Camry owner someplace or other.
Previous Topic:7MGTE Sprinter
Next Topic:MiNES ECU?
Current Time: Tue Oct 27 05:18:45 UTC 2026
Total time taken to generate the page: 0.0060040950775146 seconds
