Toymods » Tech & Conversions » Soarer air conditioner...is it the same as any OZ Toyotas?
viagra_cressida
Balranald
Soarer air conditioner...is it the same as any OZ Toyotas? Sun, 02 February 2003 10:43 Go to next message
I think my A/C doesn't just need re-gassing now. It makes a fair bit of noise and then the belts smoke and it stops itself. I was wondering would I nead just new bearings or a whole new compresser or new wheels or what? If I need new parts will a normal A/C shop be able to fix it and if so what will I tell them the part is that I need? Is it the same as a locally made Toyota air conditioner?
Thanks, Steve
Bounty
_Sydney _
Re: Soarer air conditioner...is it the same as any OZ Toyotas? Tue, 04 February 2003 07:26 Go to previous messageGo to next message
try this out might help you out a bit to find the problem.
http://www.lexus.australia.as/technical_pages/airc on_diagnostics.htm
good luck.
BansheeBuzz
Gold Coast
Re: Soarer air conditioner...is it the same as any OZ Toyotas? Tue, 04 February 2003 08:50 Go to previous messageGo to next message
From what you describe you need ne compressor. any auto elec/air con shop should be able to do it for you. expect up to $400 for a 2nd hand compressor.
wagonist
Toymods Club Treasurer
Re: Soarer air conditioner...is it the same as any OZ Toyotas? Wed, 05 February 2003 01:47 Go to previous message
Is the belt smoking , or the compressor?
I once had this problem & discovered the bearing in the tensioner pulley had seized solid.
Fix: $10
Previous Topic:RA28 diff upgrade - ideas/input etc etc
Next Topic:Single turbo upgrade for 1G-GTE engine
Current Time: Tue Oct 27 08:06:49 UTC 2026
Total time taken to generate the page: 0.064984083175659 seconds
