Toymods » Tech & Conversions » Dust cover between gear box and propeller shaft
silversup
icon5.gif  Dust cover between gear box and propeller shaft Mon, 03 February 2003 22:41 Go to next message
Hi all,
Went for a drive in the 23, on the way back I started to hear a rattling only when slowing down... Well I finally jacked up the car last night and had a look around. The source for the rattling was the dust cover, made up of two pieces, one larger cylinder that is connected to the gearbox. The other fits inside.
What I want to know is: does the smaller cylinder (that fits inside the one attached to the g'box, close to the prop shaft) actually supposed to be connected to the prop shaft? I think that it should be connected to the prop shaft and spin freely within the other cylinder. If so how is it connected?, how could it have come apart?
Any help greatly appreciated!
Re: Dust cover between gear box and propeller shaft Mon, 03 February 2003 22:55 Go to previous messageGo to next message
Yes, it should be connected to the yoke at the front of the tailshaft. It's a press-fit, so it could have worked itself loose over time as a result of vibration in the tailshaft. It's easy enough to fix though; just remove the tailshaft and bash it back into place.
silversup
Re: Dust cover between gear box and propeller shaft Mon, 03 February 2003 23:53 Go to previous message
Thanks Norbie - will do it in the next day or so!
Previous Topic:4AC Head Change Over Cost?!
Next Topic:RA 23 engine up grade options??
Current Time: Sun Nov 22 23:20:19 UTC 2026
Total time taken to generate the page: 0.0039830207824707 seconds
