Toymods » Tech & Conversions » 4agze clutch
sebta22
4agze clutch Tue, 04 February 2003 07:45 Go to next message
Some where in the forums i read that someone had used a W50 gearbox with the 4agze. If i remember rightly he said that you need to shave 5mm off the w50 bellhousing and make a 12mm adapter plate. He said you could use the 4agze clutch, flywheel and start motor. Is this true and has anyone do this?
Do you need a bearing in back of the crank to support gearbox shaft and if so how do you mount it?
Re: 4agze clutch Tue, 04 February 2003 11:47 Go to previous messageGo to next message
I can answer some of that - the 4agze clutch is suitable, and you do need a spigot bearing, which just has to be shoved into the end of the crank. Easy really! Twisted Evil
Rex_Kelway
Re: 4agze clutch Wed, 05 February 2003 01:24 Go to previous messageGo to next message
I too am looking into the 4AGZE clutch with the W50 idea. But the one thing that worries me is how available replacement clutches are considering the 4AGZE was never available on the OZ market
sebta22
Re: 4agze clutch Wed, 05 February 2003 03:11 Go to previous message
You happen to remember where you got the bearing from and what part number the bearing was??
Previous Topic:3sgte pics?
Next Topic:RA28 diff upgrade - ideas/input etc etc
Current Time: Tue Oct 27 01:19:59 UTC 2026
Total time taken to generate the page: 0.11969614028931 seconds
