Toymods » Tech & Conversions » Rust Removal
CamZH
Toodyay, WA
Rust Removal Wed, 05 February 2003 04:41 Go to next message
Hey guys,
I've got a bad build up of surface rust on the roof of the KE20.
Anyone got any great ideas on removing it easily/quickly??
thanks,
CamZH
CuRtana
Re: Rust Removal Wed, 05 February 2003 06:03 Go to previous messageGo to next message
If its just surface rust can't you give it a light sand then use some rust preventative on it. Someone correct me if I am wrong
Damian
Gabz
Melb
Re: Rust Removal Wed, 05 February 2003 06:19 Go to previous messageGo to next message
Yep that sounds about right.rust converter is a good product
CamZH
Toodyay, WA
Re: Rust Removal Wed, 05 February 2003 06:48 Go to previous messageGo to next message
Hey Guys,
Sounds like a fantastic idea!
only its not light surface rust its very heavy!!
I've tried just about everything, the flap disc's on the angle grinder work ok, but they clog up with the rust stuff.
Also underneath some of the rust there is its incredibly hard black stuff.
Sanding is working with just normal paper, but it takes forever!
CamZH
ps. also been using a phosphoric acid based rust converter.
CuRtana
Re: Rust Removal Wed, 05 February 2003 12:33 Go to previous messageGo to next message
How about those wire brushes you can get for angle grinders, they are cone shaped, they are good for removing rust and paint. Just out of curiosity, is the black stuff like a layer of paint or is it thick? I had this layer of blackish paint on my celica that was/is a bitch to remove.
CamZH
Toodyay, WA
Re: Rust Removal Wed, 05 February 2003 12:51 Go to previous messageGo to next message
The wire brush on the angle grinder doesnt touch this rust!!
and wont even think about the black stuff!!
The black stuff isnt paint, its under the rust, it seems like burnt rust?? it shows up after using the angle grinder
CamZH
munki
Gold Coast
Re: Rust Removal Wed, 05 February 2003 13:00 Go to previous messageGo to next message
1.sandblast
2.weld
3.grind back
(repeat steps 2 &3 if necessary)
4.etch prime
5.bog
6.primer
bla bla
Gased
Re: Rust Removal Wed, 05 February 2003 13:51 Go to previous messageGo to next message
Sounds too far gone.
Talk to a panel beater/sheet metal workshop. Consider carefully cutting a good roof off a wreck according to their instructions and taking it to
them. They should be able to braze it or TIG weld it on your car without too much warpage.
You can't really stop rust with rust convertor - only slow it down.
Rust sucks!
Good luck
David
CamZH
Toodyay, WA
Re: Rust Removal Wed, 05 February 2003 19:57 Go to previous messageGo to next message
We're talking about a KE20 here!
It seems that if i just get some super aggressive sand paper that might be the trick.
thanks,
CamZH
riceboy
Japan
Re: Rust Removal Thu, 06 February 2003 10:11 Go to previous messageGo to next message
CamZH this doesn't sound like a very good thing to repair. If the rust isn't too effected by an angle grinder or a wire brush attachment i would seriously be taking David's approach. Rust is car cancer and if it's in the body then it's only a matter of time. How is the rest of the body? Don't waste good money working hard on something that is a dead end if you can find a better body or a whole new roof.
If you insist on working on the roof try a 36 grit sanding disc fitted to the angle grinder, once you have grinded as much as you can off then get a power drill with a 6mm drill piece (or suitable size) and use the drill to dig out any rust you can before using some good rust converter...but it might just be easier to make the car a convertible!
CamZH
Toodyay, WA
Re: Rust Removal Thu, 06 February 2003 11:02 Go to previous messageGo to next message
Its not that bad, and the rest of the body is really good!
I just got my 9" grinder back tonight and i'll try that with a 80grit flap disc, i think the problem with the 4" grinder using the dics was the rpms, it was burning the disc and making a hell of a mess, but the 36 grit might work, i have a 40grit disc, but i dont want to attack the steel too much....
Cam
riceboy
Japan
Re: Rust Removal Thu, 06 February 2003 11:31 Go to previous messageGo to next message
Cam are you able to post a picture of the rust? I would like to see it as from your earlier post to me it sounded quite bad. If you are sure the rust isn't too deep into the metal there are no holes going right though spend some time cleaning it up. Don't get too carried away with the 40 grit paper on the thin metal (using an air tool is great as you can adjust the rpm easily).
Using that 80 grit disc strip off all the paint around the rust, take it back way passed the rusted spot as rust is like an iceberg in the way that there is usually more hiding under the surface. Hack into it with the 40 grit disc and try to get as much off as you can without making the metal too thin. If the metal is thin then don't use the drill idea or you will turn your roof into swiss cheeze but rather get a wire brush and some sandpaper (use an engraver if you can get one) and clean up any little rust divets.
In the end you will have to use some filler and spray putty anyway so don't worry if you scratch the roof up a bit.
CamZH
Toodyay, WA
Re: Rust Removal Thu, 06 February 2003 11:45 Go to previous messageGo to next message
Hey Riceboy,
I'll take a pic for you tomorrow.
Its no where near going through the roof, its just BAD surface rust. I was never going to try the drill idea as its not badly pitted. Thes rust patch is smaller now that i have worked on it for some 4-5 hours!
I'll keep you informed
Cam
CamZH
Toodyay, WA
Re: Rust Removal Fri, 07 February 2003 06:27 Go to previous messageGo to next message
Hey Riceboy,
got those pics for you.
i Havent touched it since wednesday but just about to hit it with the 9"
http://members.optushome.com.au/manjuice/rust1.jpg
http://members.optushome.com.au/manjuice/rust2.jpg
http://members.optushome.com.au/manjuice/rust3.jpg
CamZH
munki
Gold Coast
Re: Rust Removal Fri, 07 February 2003 08:09 Go to previous messageGo to next message
have you tried rust converter then the wire brush drill attachment?
it is too much to sandblast because it may damage the roof.
A new roof would be the easiest way to go about it, if you could find a decent one.
riceboy
Japan
Re: Rust Removal Fri, 07 February 2003 09:06 Go to previous messageGo to next message
Cam how did it come up after using the 9"? If things still aren't looking good perhaps it is time to get chemical!
I can't think of anything off the shelf (as i have never used chemical cleaners on rust) but you may want to look at treating it with some acid. (may need to talk to an acid dipper - not an acid tripper!) to see if you can just give the roof a bit of an acid bath. A diluted hydrochloric acid should do the trick. I would still keep sand blasting as an option as well though as the roof surface is already damaged. Things don't look too serious.
Rala
Perth, WA
Re: Rust Removal Fri, 07 February 2003 11:22 Go to previous messageGo to next message
Hey Riceboy,
the 9" wasnt so good, with the flap disc on it, it was fairly aggressive and unconsistent, ie. sometimes it would cut harshly and other it would do nothing!
It was also harder to use as when it would cut it would do it well and heat up the metal very quickly!!
The orbital sander seems to be doing well!
CamZH
CamZH
Toodyay, WA
Re: Rust Removal Sun, 09 February 2003 08:21 Go to previous messageGo to next message
Hey Riceboy!
Chemical is/was the go!!
HCl is fantastic!!
Just gotta make sure it washes off!
Heres proof...
http://members.optushome.com.au/manjuice/KE20AcidBoot.jpg
Cant stop now, only 1/2 done! Razz
http://members.optushome.com.au/manjuice/KE20AcidFront.jpg
http://members.optushome.com.au/manjuice/KE20AcidRoof.jpg
http://members.optushome.com.au/manjuice/KE20AcidSide.jpg
CamZH
[Updated on: Sun, 09 February 2003 08:24]
Re: Rust Removal Sun, 09 February 2003 08:32 Go to previous messageGo to next message
now PAINT IT!!!
i recommend PURPLE!! Very Happy
riceboy
Japan
Re: Rust Removal Mon, 10 February 2003 13:19 Go to previous messageGo to next message
Cam good to see things are working out for you. Job is coming along well now. Glad you are doing a bare metal respray, if prepped properly the result will be much better, i didn't have time for a bare metal respray and was using white so it didn't matter as much (i was also not looking at a showcar result, just something neater) but still you can see the results of cutting corners with paint. What colour will you be painting it?
Matt.
CamZH
Toodyay, WA
Re: Rust Removal Mon, 10 February 2003 19:47 Go to previous messageGo to next message
Hey Matt,
I'm still not 100% sure what colour to spray it!
We were originally thinking dark blue..
but it might end up being a mauve/purple! Smile
Any tips on spraying?
CamZH
demuire
Ipswich
Re: Rust Removal Mon, 10 February 2003 21:22 Go to previous messageGo to next message
Did the HCL strip the paint as well? Or did you use paint stripper beforehand? And I'm guessing that the HCL just ate away the rust and you just had to rub it on? Wow...
After you took away the paint and then the rust, did you prime it everytime you stopped for a day or so and then start again? Doesn't the rust come back if you just leave the bare metal out?
I'm needing to fix some rust in my Rolla as well...
Jayem
Finland
Re: Rust Removal Tue, 11 February 2003 10:50 Go to previous messageGo to next message
Whats the brand of the rust eater? HCI? that stuff really looks great. I've never used any rust converters becouse i have always had doubts about them. I hope that your rust doesnt start to bloom shortly after the painting. I did sandblast every rust spot (nothing more) that i had and covered it with Spies & Hecker 2k phosphorus-acid paint like every bare metal. Use good body-fillers 'cos they have some rust-converters in them and another aspect is that good body-fillers dont shrink after wards.
And about color, indecent orange would be the way to go... Twisted Evil
CamZH
Toodyay, WA
Re: Rust Removal Tue, 11 February 2003 11:15 Go to previous messageGo to next message
Hey Guys,
I didnt try and strip the paint with the acid, just the rust.
the acid is just hydroclauric acid (HCl).
I've been leaving the car bare, apparently the etch primer (phosphoric acid base) doesnt like being left too long. so i was planing on doing it in 1 go.
Indecent orange?
I think we've lost something in the transaltion Smile
Irridecent Orange on the other hand would look cool!
CamZH
Jayem
Finland
Re: Rust Removal Tue, 11 February 2003 12:02 Go to previous messageGo to next message
Ok! i've got crappy translator program Mad and it gave indecent for obscene hope thats somewhat better(propably not). That sucker program dont get irridecent Mad, so i've got no idea what that means but i think we mean the same. Anyhow some outrageous
orange would be cool.
Jayem
Finland
Re: Rust Removal Tue, 11 February 2003 12:03 Go to previous messageGo to next message
Yeah! bad ass orange!!!
riceboy
Japan
Re: Rust Removal Tue, 11 February 2003 13:15 Go to previous messageGo to next message
Hey Cam,
Yeah orange sounds great. Personally if i were to paint my car orange i would have to be using a rich pastel orange that was quite warm and bright and then hit it with a nice blue pearl in the clear coats that followed. I saw this done on a street machiner's FJ Holden a few years ago and it looked sensational. Otherwise if you were after a metallic orange (irridencent) i would be going for something like the HSV orange. I think if you add some white pearl into the base coat (if it hasn't got it already) it makes the paint look a bit deeper. Plus when you clear it mix a very small portion of the base coat into the clear, that makes the paint look deeper too.
Whatever colour you go for keep the pics coming. I have some pics of my respray i just have to learn how to post them.
Matt.
Jayem
Finland
Re: Rust Removal Tue, 11 February 2003 16:09 Go to previous messageGo to next message
Riceboy you took words from my mouth. I wanted to suggest blue pearl clear coat but i tought that CamZH just wanted paint and nothing fancy. Other options (my opinion) would be metallic light blue and golden pearl clear coat or metallic wine red with copper/something brown like pearl clear coat, so that it would be classy and deep color not like bloody shit Laughing . But hey it's up to CamZH and his money...
CamZH
Toodyay, WA
Re: Rust Removal Wed, 12 February 2003 10:21 Go to previous messageGo to next message
Hey Guys,
we were originally thinking a nice metallic blue..
pearl? not somehting i thought about really..
However.. Rod has offered me some paint (reddy purple with pearl) at good price and it's a offer hard to refuse, but i still need primer and etch primer!
Anyone got any idea where to go to get paint???
CamZH
munki
Gold Coast
Re: Rust Removal Wed, 12 February 2003 10:43 Go to previous messageGo to next message
go the metallic blue and a white interior!
CamZH
Toodyay, WA
Re: Rust Removal Wed, 12 February 2003 11:38 Go to previous messageGo to next message
WHITE INTERIOR???
WTF are you thinking!!
I'd burn my KE20 before it ever had a white interior!!
The windows will be dark (black) and the interior will be black also.
Cam
twincam_ke20
Castlemaine Vic
Re: Rust Removal Wed, 12 February 2003 11:49 Go to previous messageGo to next message
hmmm...dome let the EPA see those pics, all that acid on to the lawn and down the drain?! Laughing
anyways, brings back memorys to when my ke20 was in her birthday suit Very Happy
Bugman
Re: Rust Removal Wed, 12 February 2003 11:52 Go to previous messageGo to next message
interior... that just slows you down!
power to weight baby!!!
riceboy
Japan
Re: Rust Removal Wed, 12 February 2003 13:36 Go to previous messageGo to next message
Jayem i have to agree with you completely, it is Cams money and his decision. Here we are throwing around all these wild ideas yet when it came to my own Sprinter i chose boring old white! hahaha...yeah real creative! But hell, i got 4 litres of MR2 (colour code 043) white paint for $75! So the colour choice was easy. $1000 per litre paint just isn't in my budget. I also wanted a bit of a sleeper and i think white cars can be made to look quite tough without attracting too much attention. I will probably end up airbrushing something stupid on it through boredom. As for my interior, much of it will be white as i still have white paint left! But i have to take Bugman's side here...i have stripped my interior right down so i am more or less painting the the inside of the shell. My passenger is lucky they aren't sitting on an apple box when they ride with me, i reluctantly kept my passenger seat but NO STEREO! I even had the external aerial removed and welded up the hole on the RHS guard.
But again Cam good luck and keep pics coming.
Jayem
Finland
Re: Rust Removal Wed, 12 February 2003 16:56 Go to previous messageGo to next message
Riceboy, its pretty much the same here. My corona is painted about 6months ago by Spies & Hecker totally gloss black. All chromesh are well polished. I removed aerial too plus locks, all text plates and side mouldings. All mounting holes are welded shut. I like that its quite clean looking now.
I think my car is going to get new paint in year or two. Becouse i havent removed gas tank flap(?), rear door handles and i havent fabricated glass fibre hood and fenders yet and so on Cool . Other wise it should be easy spray on. Maybe it will come gloss black (again) with green pearl clear coat. My interior is yet stock but thats all I can say now->no plans. But my main interest is in chassis and engine now Razz .
Btw. 2litres paint + 2litres clear coat with pearl effect + hardeners. 170¤ if I remember correct. I asked this some while ago.
pedroenglish
icon3.gif  Re: Rust Removal Thu, 13 February 2003 13:02 Go to previous message
Another alternative is a vynel roof. I've had this done on 3 of my cars and results exceed the cost, which was around $150 per car, they come to you with prestitched cover and install, takes a morning.
Previous Topic:ST-185 or ST-205 box to replace RAV4 manual box?
Next Topic:GZ20, MA 70, GA70 Brake Master Cylinders
Current Time: Thu Nov 19 15:09:48 UTC 2026
Total time taken to generate the page: 0.0066850185394287 seconds
