Toymods » Tech & Conversions » 2TG cam timing
Jonny2TG
Tasmania
2TG cam timing Mon, 10 June 2002 03:01 Go to next message
I am thinking I may as well play with this, why not. I have a standard 2tg engine, 88222. 8.8:1 compression.
So Bill said to advance the inlet (3SGE), and retard the exhaust for more midrange. I will get regrind cams oneday, but I may as well experiment.
But this will create more valve overlap. But I know the most important valve event is the closing of the inlet valve. Advancing the inlet cam makes the inlet valves close earlier. I guess experience works better than theory in this area. I will try.
Jonny2TG
Tasmania
Re: 2TG cam timing Tue, 11 June 2002 10:42 Go to previous messageGo to next message
any one with more idears?
Karl_skewes
New Zealand
Re: 2TG cam timing Tue, 11 June 2002 11:04 Go to previous messageGo to next message
hmm, I dunno.
Thankfully the 2TGs have adjustable cam gears from factory, just go a to the next pin over on each, but as you said. Advanced inlet, retarded exhaust.
Actually, wouldn't that give you less overlap?
Good thing you use goo instead of gaskets, as the 2TG cam gears can't be changed without taking off rocker cover Razz
Karl
thetoyman75
Club President
Re: 2TG cam timing Tue, 11 June 2002 15:03 Go to previous messageGo to next message
Two things before bed Smile
Firstly,
Jonny, minor typo mate I think you meant 9.8:1 Compression.
Secondly the 88222 head has the biggest lift of any stock 2TG head I am aware of so be careful. These old girls are full impact heads so if the timing is too far out the piston will hit the valve and bugger everything ! Sad
This post is more for the newer mambers rather than you Jonny I know you are aware of that Smile
When the 88222 head was released emissions were not an issue so you can bet the stock cam timing is actually the "best" setting I wouldn't be changing it myself. IF you do tho let me know I always like new information.
Jonny2TG
Tasmania
Re: 2TG cam timing Wed, 12 June 2002 02:15 Go to previous messageGo to next message
The pistons I am useing are probably not the 88222 ones, but later. They are deifinately 8.8 and say that on the top. Which means I am missing out on some power Sad
thetoyman75
Club President
Re: 2TG cam timing Wed, 12 June 2002 10:47 Go to previous messageGo to next message
Jonny,
I was once told that on a 2TG every Compression point is worth 10 HP ! No idea if thats true but it came from a well respected mechanic so I do use it as a rule of thumb. That being the case your down 10 HP Sad
Still the 88222 was the "best" stock 2TG released so your probably still doing ok.
If you ever pull the pistons out the Head series number should be on the side Smile
inferno
Re: 2TG cam timing Wed, 12 June 2002 14:11 Go to previous messageGo to next message
hmm... i thought that the 88222 2TGs had the efi heads with the lower compression (better for turbs) and bigger valves, and the earlier 88220 heads were with the 9.8:1 compression, but then again my 220 2tg seemed dead compared to any other 222 2tg i driven, but maybe thats just 'cause it had done a few too many km's. im sure the 222 has the lower compression but Nod
anyway i guess i'm just dribbling, just wanted to know how you go with the vavle timing trick.
EMP-2TG
Carlingford, Sydney
Re: 2TG cam timing Thu, 13 June 2002 02:27 Go to previous message
i have the 88222 head on my 2tg and its 8.8 comp
as it says on the top on the pistons anyway
this is factory carby Wink
and atm is going hard Smile
Previous Topic:Tojo diff sizes/codes/ and donor cars
Next Topic:Power to weight ratio
Current Time: Mon Oct 19 18:03:36 UTC 2026
Total time taken to generate the page: 0.0073859691619873 seconds
