Toymods » Tech & Conversions » 7MGTE Sprinter
redgti2
geelong
7MGTE Sprinter Fri, 07 February 2003 01:59 Go to next message
hey guys....in the engine guide on this site, it says its possible to put a 7M into a AE86. Has anyone on here seen one like this, or done it themselves. What extra work was required and was the end result worth it. Also are there any issues about the legality of it??
rob_RA40
c'town, NSW
Re: 7MGTE Sprinter Fri, 07 February 2003 02:08 Go to previous messageGo to next message
as far as im concerned that engine swap guide isnt a very good article at all
that guide is pretty much just a list of either FWD or RWD cars that can be matched with FWD or RWD engines
this means things like whether the engine will actually fit and be legal on the street are disregarded
EDIT: most people choose an engine before seeing if its legal, i suggest u look at the requirements for vehicle modification in your states Traffic Authority and then choose an engine from there.
[Updated on: Fri, 07 February 2003 02:11]
Bigfrek6
Maitland, NSW
Re: 7MGTE Sprinter Fri, 07 February 2003 02:42 Go to previous messageGo to next message
I would tend to agree with RobRA40, find out would is legal and waht isnt, i believe some of the laws changed about 2-3mths ago, ive had a sprinter and a 7m in my garage at the same time and i think you would have the move the fire wall a fare bit to make it fit, there are easier ways of putting power into a sprinter, it just needs a little research first.
Good luck with it all.
Steve
Re: 7MGTE Sprinter Fri, 07 February 2003 03:26 Go to previous messageGo to next message
Wow, let's take a light, well-balanced chassis and shove a heavy cast-iron six in its nose. Great idea, NOT!
This engine conversion is definitely not legal in Qld or NSW, but I don't know about Victoria; as mentioned above, you should check with the relevant authorities before you make any plans.
Legalities aside, this is not a good idea. The AE86 has a short engine bay, so you'd definitely need to move the firewall (read: major re-engineering) to make a 7M fit. And even if you succeeded, you'd wind up with a car that can't turn or stop, and the torque would probably twist the frame into a pretzel the first time it came on boost. There are better ways to make an AE86 fast!
mx83toy
Re: 7MGTE Sprinter Fri, 07 February 2003 03:29 Go to previous messageGo to next message
here here
biased99
Re: 7MGTE Sprinter Fri, 07 February 2003 04:38 Go to previous messageGo to next message
If it wasn't such a hassle, one would think a 2MZ-FE would be a good proposition for a sprinter...with a nice 5-speed behind it.
Certainly the weight and it's placement would have to be close to/as good as most replacement 4's?
Re: 7MGTE Sprinter Fri, 07 February 2003 08:12 Go to previous messageGo to next message
I reckon one of them would be sweet in an old Celica also. Problem is hooking up a RWD gearbox (none exist from the factory) plus sorting out manifolding... it wouldn't be cheap.
biased99
Re: 7MGTE Sprinter Fri, 07 February 2003 13:59 Go to previous messageGo to next message
...Thus the reference to "such a hassle"...
Still, if money (and time) wasn't an object... Smile
redgti2
geelong
Re: 7MGTE Sprinter Sat, 08 February 2003 02:18 Go to previous messageGo to next message
thanks for all the info and help guys. After a bit more reading (i know i should have done that first) i can see it wouldnt really work to the way i was thinking. I will now investigate the 3sgte and 4agze route's and see how i go.
Re: 7MGTE Sprinter Sat, 08 February 2003 11:47 Go to previous message
Hey, don't be discouraged - after all, the authorities allowed Ford to produce the 4.1 litre cortina!
(I still think a 7M into an AE86 is a silly idea! Very Happy )
Previous Topic:What Comes in a HalfCut
Next Topic:Calling all mechanics....how to remove Camry drive axles from transaxle??
Current Time: Mon Oct 26 05:48:17 UTC 2026
Total time taken to generate the page: 0.036154985427856 seconds
