Toymods » Tech & Conversions » AE86 wheel upgrade
Poolshark
AE86 wheel upgrade Fri, 07 February 2003 13:08 Go to next message
can i put 16 inch wheels on a sprinter without changing the suspension
thoughts anyone
Poolshark
Re: AE86 wheel upgrade Fri, 07 February 2003 13:11 Go to previous messageGo to next message
i want to put ROH16 zs on
16x8.5" ROH ZS Rims
ZS 1685
will they go ok without changing to over coils or coil overs what ever you want to call them
[Updated on: Fri, 07 February 2003 13:14]
Poolshark
Re: AE86 wheel upgrade Fri, 07 February 2003 13:15 Go to previous messageGo to next message
any help would be great
thanks heaps guys
great site here
LiL_MiC
Melb
Re: AE86 wheel upgrade Fri, 07 February 2003 13:29 Go to previous messageGo to next message
16's will fit
Poolshark
Re: AE86 wheel upgrade Sat, 08 February 2003 02:51 Go to previous messageGo to next message
i thought i better check that i didnt need to change suspension before i got them
LiL_MiC
Melb
Re: AE86 wheel upgrade Sat, 08 February 2003 03:53 Go to previous messageGo to next message
u should keep the same rolling diameter [with lower profile tyres] and make sure you have the right offset if u dont want the tyres to scrub everywhere inside
Poolshark
Re: AE86 wheel upgrade Sat, 08 February 2003 04:32 Go to previous messageGo to next message
yer there is a little clearance
im just worried about the suspension at the fornt getting in the road
Poolshark
Re: AE86 wheel upgrade Sun, 09 February 2003 11:28 Go to previous messageGo to next message
so the 205 tires wont be a prob?
anyone running 205 tires on a sprinter?
Ribbo
Northern Beaches
Re: AE86 wheel upgrade Sun, 09 February 2003 12:27 Go to previous messageGo to next message
im pretty sure fergo is running 205's with no worries
Sam
Sydney, Australia
Re: AE86 wheel upgrade Mon, 10 February 2003 02:38 Go to previous messageGo to next message
I'm running 205's on my sprinter, they're 55 series as well, no real problems apart from the left tire scraping a bit on the chassis under compression, but this is more likely due to stuffed shocks.. Sad
edit: I should have mentioned that these are on 15" wheels.
[Updated on: Mon, 10 February 2003 02:40]
Poolshark
Re: AE86 wheel upgrade Mon, 10 February 2003 08:24 Go to previous messageGo to next message
and sam you have the normal suspension and setup at the front?
or have you modded a bit
Poolshark
Re: AE86 wheel upgrade Mon, 10 February 2003 08:25 Go to previous messageGo to next message
cause im worried about the width not the hieght
the tires are 45's
Poolshark
Re: AE86 wheel upgrade Mon, 10 February 2003 08:26 Go to previous messageGo to next message
im also worried about my spelling
Razz
Poolshark
Re: AE86 wheel upgrade Tue, 11 February 2003 00:13 Go to previous messageGo to next message
well hopefully they go on
time will tell though
im going down wednesday to get them
Sam
Sydney, Australia
Re: AE86 wheel upgrade Tue, 11 February 2003 00:37 Go to previous messageGo to next message
Poolshark wrote on Mon, 10 February 2003 19:24
Completly bog stock standard, apart from sway bars..
fOOZ86
Re: AE86 wheel upgrade Wed, 12 February 2003 10:08 Go to previous messageGo to next message
To prevent wheel rub? I get bad wheel rub.. with standard wheels, I dunno why! Sad
joyride
fairfield NSW
Re: AE86 wheel upgrade Wed, 12 February 2003 20:24 Go to previous messageGo to next message
8.5 inch wide tyres is a bit excessive dont u think? unless u have a beast under the bonnet i dont really see the point.
i'm not trying to flame you dude but u also have to consider if insurance will cover u.
good luck Cool
4AGE
Re: AE86 wheel upgrade Thu, 13 February 2003 06:31 Go to previous messageGo to next message
What u can do is get a set of deep dish rims... U need to offset to keep it away from your strut in most cases. 16" fits nicely if u put a 10mm spacer in behind the wheel hub... A bit of handy work with a oxy torch is needed. That way your wheel assembly is still 1 piece and road legal. I've got 205s by 50 on rear n 195 50 on front. 16".
Another solution is to get the studs from a landcruiser n whack them in and saw off a bit of the stud... Works the same.. Probably better Razz
Re: AE86 wheel upgrade Thu, 13 February 2003 10:33 Go to previous messageGo to next message
I've got 16x6.5" wheels with 205s on the front and 215s on the back, all fits no worries. If I get the guards played with a bit I could readily stuff 225s in there.
steeko
Re: AE86 wheel upgrade Fri, 14 February 2003 03:10 Go to previous message
I'm in bris.. i got some 16X7 ROH ZS rims from my 83 celica.
They're custom made and offset, i had them made in 1999.
Cost me over $2500.
They've travelled maybe 1000 Kms max (a couple of weekends).
But i can't get insurance on em till I's over 25 which is about 12months away. The tyres still got the little nobbily bits on em, LOL.. Running directional Dunlop Tyres - FM901 - 205/45 front and back, they came 2nd in a test of 10 tyres in Wheels magazine, some Falkens won.
Pretty sure the sprinter has the same stud pattern and offset, but I'm considering selling them.
I can get some pics etc if you're interested..
They're only 16X7 so they dont have a huge deep dish or nothing, but they look pretty big on a small car.
I'm saving up for some smaller 13" rims.
Have u considered putting MA60 supra rims on?? they look fat on a sprinter!
btw.. my email:
steeko@lowrider.com
steeko@hotmail.com
Previous Topic:ma70 brakes turbo vs n/a
Next Topic:Is this possible???
Current Time: Sat Nov 21 15:50:50 UTC 2026
Total time taken to generate the page: 0.0092599391937256 seconds
