Toymods » Tech & Conversions » 1JZ sumps
Milhouse
1JZ sumps Sat, 08 February 2003 02:12 Go to next message
Does anybody know what model and year of auto 1JZGTE powered cars came out with a front mounted sump? I want to know which front cut is most suitable for a MX73 Cressida.
Manny
Re: 1JZ sumps Sat, 08 February 2003 10:26 Go to previous messageGo to next message
According to the xJZ workshop manual, the JZS147, JZX90 & JZX91 came with front sumps. Hope this helps.
wilbo666
Re: 1JZ sumps Sat, 08 February 2003 11:42 Go to previous messageGo to next message
also JZX81 aka Chaser, what the MX83 boys used for their conversion. Smile
[Updated on: Sat, 08 February 2003 11:47]
humble
Brisbane, QLD
Re: 1JZ sumps Sun, 09 February 2003 05:20 Go to previous messageGo to next message
Also, the 2JZ aristo and a Lexus xx300 also came with a front sump, which will bolt up to a 1JZ block.
Milhouse
Re: 1JZ sumps Sun, 09 February 2003 07:09 Go to previous messageGo to next message
Thanks guys. So all Soarer half cuts definitely would not have front sumps then?
Manny
Re: 1JZ sumps Sun, 09 February 2003 11:14 Go to previous messageGo to next message
Definately not front sump - Soarer is rear sump, same as JZA70 & JZA80 Supras
thunderbird1
Sydney Australia
Re: 1JZ sumps Sun, 09 February 2003 14:30 Go to previous messageGo to next message
i have a mx73 1jzgte, u need front sump. end of story.
wilbo666
Re: 1JZ sumps Sun, 09 February 2003 14:39 Go to previous messageGo to next message
Why have most of the newer cars moved away from front sumps?
Does it make it easier to move the engine deeper into the engine bay?
Re: 1JZ sumps Sun, 09 February 2003 23:04 Go to previous messageGo to next message
The type of sump depends on the crossmember it has to fit over, which in turn is related to the type of suspension used. For example, the Supra moved from front sump to mid sump at the same time they changed from mcpherson strut to double wishbone suspension.
wilbo666
Re: 1JZ sumps Mon, 10 February 2003 00:16 Go to previous messageGo to next message
Ahh yep, that makes sense, didn't even think about that Embarassed
1jzmx83
Re: 1JZ sumps Mon, 10 February 2003 03:37 Go to previous messageGo to next message
nice post Milhouse, I coulda told you that! Smile
Milhouse
icon10.gif  Re: 1JZ sumps Mon, 10 February 2003 11:30 Go to previous messageGo to next message
Yeah thanks 1jzmx83 I forgot you were the expert! Just joking by the way
Browndog
Re: 1JZ sumps Mon, 10 February 2003 11:56 Go to previous messageGo to next message
So will any 1jz or 2jz with a front sump be a good fit in an MX83?
[Updated on: Mon, 10 February 2003 11:57]
ROBBO_ma61
Re: 1JZ sumps Mon, 10 February 2003 11:58 Go to previous messageGo to next message
2jz aristo has a front sump if nobody already said. Could be a tricky part to find..parhaps get a custom one built..
deesonet
Toowoomba
Re: 1JZ sumps Tue, 11 February 2003 12:08 Go to previous message
When I stuck a 1JZGTE into a VL for my son we built a new sump to suit the required location. It is quite easy as the 1JZ has the upper cast aluminium piece then the lower steel piece.
We replaced the lower steel piece to make a front sump 1JZ from a rear sump 1JZ. While we were at it we increased the oil capacity to nearly 7 litres.
The only tricky part was had to move the oil pickup as well. Hope you can think and measure in 3 dimensions.
Previous Topic:Corona MK2
Next Topic:How the F%$#@ do i remove the rear seat?!?!
Current Time: Sun Nov 22 10:21:56 UTC 2026
Total time taken to generate the page: 0.0066928863525391 seconds
