Toymods » Tech & Conversions » Another 1J Cressie! :) (prob...O/D Light)
frebbles
Another 1J Cressie! :) (prob...O/D Light) Sat, 08 February 2003 18:53 Go to next message
Laughing Very Happy Very Happy Very Happy Laughing
Yeehaa! Smile It's running and I drove it last night, it's amazing, just totally blowin me away!!!! Nothing can wipe the cheesy ass grin off my face...
A quick thanks to all you toymods guys who've been such great helps over the past few months and year, I've learnt so much from you and I am extremely thankful, the convo wouldn't have happened without your help.
I have one question, (hence the reason this post is in the tech section) I have the O/D Light flashing on the dash, which is an error code, now I have some of the info Grant sent me and it says that it could be speed sensor one or two however...
Speedo works (Runs off SP1)
Cruise works (Runs off SP2)
So could there be a problem with the fact that cruise is sapping power from the sp2 line or something?
Or it could be a solenoid?
Anyone out there have this happen? How did you resolve it?
Thanks.
[Updated on: Sat, 08 February 2003 18:56]
frebbles
Re: Another 1J Cressie! :) (prob...O/D Light) Mon, 10 February 2003 01:56 Go to previous messageGo to next message
Ok did the diagnostics thing and have confirmation on the SP2 Sensor being out compared to the SP1 sensor according to the ecu...which I dont understand as if one is out then the other would be too, I assume that it thinks the one with lower register is the one that is malfunctioning. However the cruise is working off the SP2...
So my questions are...
Anyone have a spare Speed Sensor 2 lying around?
And for Grant. Does the input to the cruise control take so much current that I should wire up some sort of op amp to stop the ecu complaining?
Am in the process of disconnecting the cruise for more troubleshooting.
thunderbird1
Sydney Australia
Re: Another 1J Cressie! :) (prob...O/D Light) Mon, 10 February 2003 04:39 Go to previous messageGo to next message
i've put up with the flashing light for over a year now.. forgotten about it.. only time it pisses me off is when i have to explain to someone that nothing is wrong Smile
Apollo
Brisbane, QLD, Australia
Re: Another 1J Cressie! :) (prob...O/D Light) Mon, 10 February 2003 05:31 Go to previous messageGo to next message
Just do what homer does to the check engine light.
Put a bit of black tape over it. Razz
Cressida Supra
Re: Another 1J Cressie! :) (prob...O/D Light) Mon, 10 February 2003 14:03 Go to previous messageGo to next message
i'll second that.
i just havent got around to taking the globe out
Peewee
Grant
Newcastle, NSW, Australia
Speed Sensors Wed, 12 February 2003 00:21 Go to previous messageGo to next message
Farren,
As the fault code indicates, you have no signal from SP2 to the ECU. This is a common problem as the Chaser (and Cressida) use a unique secondary speed sensor that cannot be fed directly into the ECU. Cruise control definitely does not operate from the secondary speed sensor; only the primary speed sensor. I'll explain:
All Toyota's use 2 speed sensors; SP1 being the primary speed sensor and SP2 being the secondary or backup speed sensor. SP1 is used for things like Engine/Auto ECU, Cruise Control, A/C and Power Steer while SP2 is used as a backup to allow the auto to still shift (and get you back home).
Chasers (and Australian Cressida's) are a special case. SP2 is actually a multi-tooth sensor primarily used to act as the rear ABS sensor. The ABS computer then converts this signal and sends it to the engine ecu as the backup speed sensor. Unless you have ABS on your Cressida you will not be able to use this sensor.
If you have the original box and your Cressida does NOT have ABS, you can swap the sensors to provide you with the backup signal the ecu is looking for.
[Updated on: Wed, 12 February 2003 00:24]
frebbles
Re: Another 1J Cressie! :) (prob...O/D Light) Wed, 12 February 2003 03:34 Go to previous messageGo to next message
Ok I do have ABS on the car, and I've tested it and it worked (to my surprise...)
So now what can I do to eliminate the flashing?
I seem to remember hooking the SP2 signal to the Cruise (???)
and the cruise works so I'm confused.
I can understand what you are saying but something doesn't add up. I'll have another look when I get home to confirm.
Grant
Re: Another 1J Cressie! :) (prob...O/D Light) Wed, 12 February 2003 03:48 Go to previous message
If you have hooked up SP2 to the cruise then you probably missed connecting to the ecu. I would connect SP1 to cruise and connect SP2 to the ecu.
Previous Topic:5M-E cold starting
Next Topic:Microtech tuning for 4age 20valve
Current Time: Thu Nov 19 22:32:42 UTC 2026
Total time taken to generate the page: 0.0051810741424561 seconds
