Toymods » Tech & Conversions » 2tg - NO DISTRIBUTOR
celicamad85
Banned member
2tg - NO DISTRIBUTOR Sun, 09 February 2003 04:10 Go to next message
gday
bought a custom plenum job off these forums went to fit it and find out the dizzy is in the way take it off and no problems
so my question is has or does anybody here know off a crank angle sensor and coil packs i can use on the 2tg , i.e. 3sgte or some aftermarket types ?....will be using a vortech blower on this setup too so im after some computer suggestions at the same time, one with variable timing per pound of boost
wayne
celicamad85
Banned member
Re: 2tg - NO DISTRIBUTOR Mon, 10 February 2003 08:09 Go to previous messageGo to next message
so nobody on these forums knows anything about 2tg's with crank angle sensors ??
Re: 2tg - NO DISTRIBUTOR Mon, 10 February 2003 08:44 Go to previous messageGo to next message
I think the problem is that no one has used it. Crank angle sensor is different to a hall-effect sensor am I not right?
Thats the route I would be going if I was going to remove a dizzy from my engine and use aftermarket ECU.
celicamad85
Banned member
Re: 2tg - NO DISTRIBUTOR Mon, 10 February 2003 09:10 Go to previous messageGo to next message
to the best of my knowledge the hall effect is slightly not as accurate + or - 0.2 degrees where crank angle is + or - 0.1 degrees each would be as easy as the other to setup just need to know if anybody has tried this and what brands are recommended etc. does anybody actually have a 'kit' for a 2tg or it looks like i am going to have to go custom everything again, talk about the frankenstein car, bit of this and that everywhere
Re: 2tg - NO DISTRIBUTOR Mon, 10 February 2003 09:15 Go to previous message
Wouldn't a Hall Effect Sensor be easier to set up, as most of them are just generic? Just a thought...
Previous Topic:5me alternator
Next Topic:1g-gte overheating
Current Time: Wed Oct 28 03:52:32 UTC 2026
Total time taken to generate the page: 0.0054800510406494 seconds
