Toymods » Tech & Conversions » Crank sensor on 1jz-gte (installing a Wolf3D)
jbrough
Crank sensor on 1jz-gte (installing a Wolf3D) Sun, 09 February 2003 12:38 Go to next message
I have bought a Wolf3D to run a 1JZ-GTE conversion. The ECU manual talks about the different crank sensor it can use, and the timing. What sort of crank sensor do these motors use? The installation book also talks about the sensor being 60 degrees BTDC, is the Toyota sensor anything like this?
[Updated on: Fri, 14 February 2003 06:08]
Youngy
Eskilstuna, Sweden
Re: Cank sensor on 1jz-gte (installing a Wolf3D) Sun, 09 February 2003 12:45 Go to previous messageGo to next message
It may help you if you talk to Alex Blackson of Alex Blackson automotive.
He just finished setting up a crank angle sensor etc on my friends 20V, and he deals with Wolf 3D gear. Not sure if he has any specific IJZ experience, but it would not be that different from other motors really.
He's in Sydney on 02 9938 1992
GTI16V
CROMER, NSW
Re: Cank sensor on 1jz-gte (installing a Wolf3D) Sun, 09 February 2003 21:19 Go to previous messageGo to next message
Alex has many yearsof experience in installing wolf's into a variety of different cars,ranging from rotaries to v8's. What sort of ingniition setup are you using?Is it a multi-coil arrangment cause these are the most reliable.
alex is located in Brookvale and has his own dyno.so he can tune it for you aswell.There are a few members here that have ha him do work on there cars and he produces the results if you do what he tells you to do.
Regards
P.H.
Pete
gold coast
Re: Cank sensor on 1jz-gte (installing a Wolf3D) Mon, 10 February 2003 10:09 Go to previous messageGo to next message
This is what your after.
http://home.austarnet.com.au/petew/JZ/CAS.jpg
I drew this on CAD. You will need to check the actual ignition timing with a timing light at idle. This will tell you how many degrees the sensor is out.
jbrough
Re: Cank sensor on 1jz-gte (installing a Wolf3D) Tue, 11 February 2003 00:10 Go to previous message
Thanks for that guys. Peter, that drawing is great. What else can you tell me about the 1JZ that I should know. I am amazed that there are not more of these engines appearing in Holdens.
Do you have a web page featuring the car?
My car is www.users.bigpond.com/jbrough/lakes/lakes.html. I am striving to get the thing running for the Dry lakes meeting next month.
Previous Topic:Dash wiring (general)
Next Topic:4agze wiring help!!!! PLEASE
Current Time: Sat Oct 31 13:16:43 UTC 2026
Total time taken to generate the page: 0.045326948165894 seconds
