Toymods » Tech & Conversions » 5M-E cold starting
wilbo666
5M-E cold starting Mon, 10 February 2003 02:35 Go to next message
When I start my 5M-E Cressida (when cold) it starts fine, but then either dies straight away, or drops to about 500 rpm and then kinda surges its was back to idle, it is hard to explain.
I think its the cold start injector as it starts perfectly when it is warm. I removed the injector and watched it spray into a jar and I didn't spray a nice spray, more kinda dribbled (but a bit came out still).
Any opinions?
ROBBO_ma61
Re: 5M-E cold starting Mon, 10 February 2003 07:17 Go to previous messageGo to next message
a normal problem. My supra used to do it too. Starting injectors. Just keep your foot on the throttle for a little while when you start it until you can feel it idlying smooth.
humble
Brisbane, QLD
Re: 5M-E cold starting Mon, 10 February 2003 08:06 Go to previous messageGo to next message
Wilbo,
The most likely cause of your problem (by the sounds of it) is the cold start air bypass valve which opens up when the engine is cold and allows air into the engine by-passing the throttle body. This valve is known to disfunction after a fair bit of use. So if you can replace it (or even adjust it if that is possible by taking it apart), that would be the go.
Good luck.
wilbo666
Re: 5M-E cold starting Mon, 10 February 2003 09:39 Go to previous messageGo to next message
ROBBO_ma61 wrote on Mon, 10 February 2003 18:17
Yep that is what I do atm, funny thing is that if the AC is on the car starts perfectly!
How does the AC thing work maybe I can mimic it?
Will have a look at the Air bypass valve tomorrow...can you take it apart?
Cheers Wilbo
ROBBO_ma61
Re: 5M-E cold starting Mon, 10 February 2003 10:17 Go to previous messageGo to next message
i wouldnt bother pulling things like the air by pass valves apart...they're an old engine lets face it...its just something we have to live with...i've never noticed it started ok with a/c on...dont run it to start the car in the morning... lol my a/c causes the car to stall cos it doesnt kick in the revs to equal up the engine...revs as about 300rpm lol anybody know how to fix that?
[Updated on: Mon, 10 February 2003 10:19]
Pumpkin
Toymods Board Member
Re: 5M-E cold starting Mon, 10 February 2003 10:25 Go to previous messageGo to next message
Isn't there a idle up on the plenum for the A/C?
ROBBO_ma61
Re: 5M-E cold starting Mon, 10 February 2003 10:26 Go to previous messageGo to next message
where the hell do i find that? YEah in hot weather im getting really sick of it stalling as i change down about 50 metres from the traffic lights.
ZZT231
melbourne.vic.au
Re: 5M-E cold starting Mon, 10 February 2003 11:37 Go to previous messageGo to next message
wilbo666 wrote on Mon, 10 February 2003 20:39
The valve sits on top of the Thermostat housing. A hose from the intake after the resonator leads into it, from there it is connected to the inlet manifold with another hose. It is connected with the color blue connector. if you decide to remove it for a small look, careful of the 2 hoses connected to the lower part of the valve, it is connected to the cooling lines.
As for pulling it apart. Can't help you there.
I had similar problems and got given one by GT. It solved all my cold starts in the morning and threw the old one into the back paddock and shot it.
PS. Not many hoses remain in Australia that lead into and from the cold start by-pass valve. One cost me $34.
wilbo666
Re: 5M-E cold starting Mon, 10 February 2003 11:45 Go to previous messageGo to next message
Ahh ok, I know the one, from memory it sits on top of the temp thing and doesn't actually have coolant hoses coming into it, just the other two. Will see if a clean out with carby cleaner will help.
Also when should I change the fuel filter? I don't know when it was last changed so should I change it for my piece of mind?
ROBBO_ma61
Re: 5M-E cold starting Mon, 10 February 2003 11:49 Go to previous messageGo to next message
they should be fine unless u retire with the engine...and everyone knows u wont Smile main good maintenance is running genuine toyota parts like oil filters and air filters...believe it or not they help with engine life compared to ryco or other brands.
ZZT231
melbourne.vic.au
Re: 5M-E cold starting Mon, 10 February 2003 12:02 Go to previous messageGo to next message
My fuel filter was replaced in 1992 though has only travelled 40,000. By looks of the petrol filter it might be a bugger to replace since it sits below the intake manifold. All the cars we own breaths through K&N Airfilter.
ROBBO_ma61
Re: 5M-E cold starting Mon, 10 February 2003 12:05 Go to previous messageGo to next message
element or pod filter? I was thinking of putting a pod on mine a while back but too much trouble...had to take off cold air pump...plug lines to head and other stuff...
ZZT231
melbourne.vic.au
Re: 5M-E cold starting Mon, 10 February 2003 12:10 Go to previous messageGo to next message
Um... To keep the car Stock... What do you think?
wilbo666
Re: 5M-E cold starting Tue, 11 February 2003 07:23 Go to previous messageGo to next message
Ok had a look at the thing today and cleaned it out a bit, however I'm pretty sure that won't effect the cold starting (when cold it should be closed so there is more fuel and less air! Richer = more likely to start), I think the problem might lie in the cold start temp sensor which is part of the Air Bypass Valve.
EDIT: Ok the above paragraph might be wrong? Maybe the Air Valve should be open when cold and closed when hot meaning mine is broken? Any help on this one, humble?
Anyone have one they want to donate? (I'll pay postage of course!)
Also how much does a K&N filter cost?
[Updated on: Tue, 11 February 2003 08:51]
ROBBO_ma61
Re: 5M-E cold starting Tue, 11 February 2003 07:58 Go to previous messageGo to next message
forget about the cold start thing ay. Theyre an old engine and it isnt worth looking around for...you just have to live with...if u so desired take it to an auto elec or mechanic.
wilbo666
Re: 5M-E cold starting Tue, 11 February 2003 08:03 Go to previous messageGo to next message
Live with it...smeh!
If it is a part I can get for $5 why would I NOT worry about it? Mad
Its the little things like this that can make your car so much better! I bet if your low fan speed setting didn't work you would go "ahh its old, I don't wanna worry about it" when you could fix it for free alomst.
So if its fine with you I will worry about it! Very Happy
ROBBO_ma61
Re: 5M-E cold starting Tue, 11 February 2003 08:06 Go to previous messageGo to next message
ok mate...you do that.. the part may be $5 but who r u gonna pay to go looking for it? It might be the starting injectors...it could be anything...
wilbo666
Re: 5M-E cold starting Tue, 11 February 2003 08:47 Go to previous messageGo to next message
Well I don't think its the cold start injector as I have already checked that, would be nice to know if it should be a fine mist tho or the kinda dribble I get Smile
That leaves the Cold start injector time switch (if it was this I would expect the cold start injector not o work at all) or the Air Valve.
Thanks for you help but this is a long term thing which I plan to keep fiddling with until I get it fixed, weather that be by making the car think the ac is on (when it is not) for say the first 15 seconds or the AV or Time switch I am not sure yet Cool
[Updated on: Tue, 11 February 2003 09:22]
Re: 5M-E cold starting Tue, 11 February 2003 11:52 Go to previous messageGo to next message
Yeah, check it all out.... Cold start injectors always spray a horrible mess, but it should still be better than a dribble. Check the thermotime switch, and the air bypass valve should be open when its cold to let more air in for a faster idle.
ed_ma61
Lost in the K hole
Re: 5M-E cold starting Wed, 12 February 2003 04:33 Go to previous messageGo to next message
ROBBO_ma61 wrote on Mon, 10 February 2003 21:17
guess you should just put up with the car stalling robbo. its old, what do you expect... why waste everyones time trying to help you huh??
mrshin: cold air bypass should be fully open when cold, and slowly close as the temp increases. the cold start injector switch should be on when cold, and switch off at operating.
cold start spray should be a fine mist, not a dribble. youll be horribly riching out cyls 3+4 and leaning out 1,2,5,6. that could potentailly stall things.
is the EGR valve working properly?
are you sure all the vac hoses are patent? have you tried simply running some carby cleaner thought the trottle body whilst the car is hot? you could also try sucking a bottle of redex through a vacuum hose when hot, maybe clean a few things up.
let me think about this one Smile
ed
wilbo666
Re: 5M-E cold starting Wed, 12 February 2003 04:44 Go to previous message
Just in case anyone cares I think the problem is the ABV as mine is CLOSED when it is cold...I pulled the hose coming out of the ABV so as to mimic the ABV being open and it started fine!
Robbo I think your problem is the vacuum idle up setting (you can set it) its on the plenum right near the front its a small little plastic screw as you look from the inside of the car to the front down the motor. This screw is meant to control the amount of idle up. Either that or the idle up vacuum valve isn't working.
SO if anyone has a ABV (and maybe a cold start injector) they want to get rid of let me know otherwise I will hit the wreckers. How much is it to get the cold start injector cleaned?
[Updated on: Wed, 12 February 2003 04:50]
Previous Topic:Hydraulic suspension supplier & legality
Next Topic:Another 1J Cressie! :) (prob...O/D Light)
Current Time: Thu Nov 19 21:54:13 UTC 2026
Total time taken to generate the page: 0.0072619915008545 seconds
