Toymods » Tech & Conversions » 18RC timing chain replacement
CuRtana
18RC timing chain replacement Mon, 10 February 2003 12:10 Go to next message
Ok, I have been told that to replace the timing chain on an 18rc, you need to remove the head and the dizzy and sump and stuff, this seems a bit of overkill just to replace the timing chain. Is it necessary to remove the head etc. or can I just take the timing chain cover off and do it that way?
Damian
Re: 18RC timing chain replacement Mon, 10 February 2003 14:42 Go to previous messageGo to next message
Well you definitely don't need to take off the cylinder head to replace a timing chain! You'll probably have to remove the rocker cover, but that's a whole lot easier.
BlueRocket
Gippsland Victoria
Re: 18RC timing chain replacement Tue, 11 February 2003 14:59 Go to previous messageGo to next message
i tried replacing the timing chain without removing the head. i could get it all off alright but found that i could not get the cover back on again as the new chain was in the way. as i could not be stuffed taking the head off i chopped a piece of the cover off and bolted it on seprately. not the best way but it worked temporarily. i have since blown that motor up and am getting another one.
i suggest to just take the head off and do it propely in the first place. its a real prick of a process but it will save a lot of trouble later down the track, and change both chains as well as the chain guides otherwise it may give you further trouble.
CuRtana
Re: 18RC timing chain replacement Tue, 11 February 2003 23:36 Go to previous messageGo to next message
Christ, if I have to take the head off, I may as well get a shop to change the timing chain as it will be a lot quicker! Why do they make it so bloody complicated to replace a bloody timing chain Smile
Damian
rob_RA40
c'town, NSW
Re: 18RC timing chain replacement Tue, 11 February 2003 23:38 Go to previous messageGo to next message
that piece of the front timing cover that gets in the way of the chain is a bitch! its like just one little useless lip on the edge of the cover FFS!
what we did to get around this was to not join the chain, fit the chain with the join up the top and stick a bit of wire in each end of the chain, then we dropped the chain down far enuff to get the timing cover on past the slack chain and then lifted the ends of the chain up and then joined the chain.
was a couple of years ago now thats as much as i can remember.
CuRtana
Re: 18RC timing chain replacement Wed, 12 February 2003 02:55 Go to previous messageGo to next message
Thanks of ryour help guys, i gotta get the timing chain done, then the clutch, then my new engine is ready to go in.
Damian
simulant
Sydney - Northern Beaches
Re: 18RC timing chain replacement Thu, 13 February 2003 11:34 Go to previous messageGo to next message
After replacing both timing chains on my 18rc 2 weeks back, I can say, if your going to do it, do it properly. Yes the people at toyota were smoking something when they decided that you'd need to take the head off to replace a bloody timing chain but, if you do it properly then at least you really have the right to bitch about it then. My motor had eaten it's top chain guide, and broken the botom chain guide.
To be honest, not only did I pull the head off, I removed the whole engine, much easyer to work on and heaps quicker than stuffing around having a bitch of a time getting at all the bloddy bolts you cant see, hidding behind the fuel pump and air con. Anyway, it's crap design, but it does work at least.
CuRtana
Re: 18RC timing chain replacement Thu, 13 February 2003 12:12 Go to previous messageGo to next message
Yeah well I am doing the timing chain on my replacement engine which is not in the car Smile so that makes the job a bit easier
DAmian
M.W.P.
Rocky Mountains, Canada
Re: 18RC timing chain replacement Sat, 15 February 2003 02:37 Go to previous messageGo to next message
So how much did it cost you guys for the chains, guides ang cogs (or whatever they are called)?
I think ill need to do mine shortly.
simulant
Re: 18RC timing chain replacement Sat, 15 February 2003 10:57 Go to previous messageGo to next message
I think I paid $20 each for the new timing chains and probably about $30 for the other bits from pick a part, so they weren't new, but they didn't have teeth missing or in the case of the guides snaped in half and eaten.
Jason
Re: 18RC timing chain replacement Sat, 15 February 2003 13:54 Go to previous message
You can go to repco or autopro or most other auto shop for that matter and buy a new kit for 18r's in it you get upper and lower chain and all the guides when i bought mine about 4-5 months ago it cost me about $70 from autopro i didnt see the point in frigging around with old chains when the engine was apart anyway.
Previous Topic:Platinum or copper?
Next Topic:warped wheels
Current Time: Mon Oct 19 17:45:33 UTC 2026
Total time taken to generate the page: 0.068713903427124 seconds
