Toymods » Tech & Conversions » oil pump and plate
Leighp
NY
oil pump and plate Tue, 11 February 2003 02:26 Go to next message
Quick question:
Is the oil plate on a 4A-ge block the same as that off any 4a (4a, 4a-c, 4a-f, 4a-fe) block? will they bolt onto the 4A-GE with no hassles and if all are compatible where can i get one?
Leigh
Grega
melbourne.victoria.austra...
Re: oil pump and plate Tue, 11 February 2003 06:00 Go to previous messageGo to next message
leigh what do you mean by plate? from what i gather they all use the same oil filter, are you referring to the sandwich plate for the oil cooler setup on the 100kw and MR2 motors?
Re: oil pump and plate Tue, 11 February 2003 12:22 Go to previous messageGo to next message
You mean the plate on the top of the sump? I'm pretty sure they're all the same.
Leighp
NY
Re: oil pump and plate Tue, 11 February 2003 13:09 Go to previous messageGo to next message
on the side of the block that is just under the timing belt
MaNGeW
Formerly TRD_RoLLa
Re: oil pump and plate Tue, 11 February 2003 13:54 Go to previous messageGo to next message
the rear main oil seal is different on 20V to 16v i think.
dunno about the front main oil pump.
Leighp
NY
Re: oil pump and plate Wed, 12 February 2003 06:04 Go to previous messageGo to next message
I am using a 16v block, water pump and 20v pistons and rod, it is a hybrid motor, wanna see what happens with it
IRA11Y
Club Member
Re: oil pump and plate Wed, 12 February 2003 08:29 Go to previous messageGo to next message
I can show you exactly what happens with it Smile
IRA11Y@hotmail,com
theyre all the same
do you mean behind the belt? as in the timing cover backing plate???
20V is different and cant be used unless you are going to use the 20V cam covers which means you have to use the 20V head. Just use the 86/100Kw backing plate
[Updated on: Wed, 12 February 2003 08:33]
Leighp
NY
Re: oil pump and plate Thu, 13 February 2003 01:28 Go to previous messageGo to next message
THANKS iRA11Y, U ROCK MATE, TRUELY A 4A-GE GURU
so what u r saying is a plate off a 4a, or a 4a-fe would work on a 4age block, i am using a 4age block with a 20v head on it, as for the side covers that bolt on i think i will use the bottom 2/3 parts of a 4age 16v and use nothing over the 20v head, or modify a 20v cover to fit.
so does anyone have a oil plate for sale same with a harmonic balancer for a 4age???
IRA11Y
Club Member
Re: oil pump and plate Thu, 13 February 2003 01:33 Go to previous message
If youre using a 20V head then use the very bottom cam belt cover of any of the 4A's theyre all the same, #2 and Top covers use the 20V covers with the 20V cam cover backing plate, the 100Kw and 86Kw backing plate have different location hole to mount the front covers on so you cant use them for the 20V top covers
Previous Topic:2S-C Unleaded, and leaded
Next Topic:intercooler help
Current Time: Thu Nov 19 14:40:45 UTC 2026
Total time taken to generate the page: 0.11267399787903 seconds
