Toymods » Tech & Conversions » Battery relocation...
biased99
icon12.gif  Battery relocation... Tue, 11 February 2003 05:31 Go to next message
I'm thinking of relocating the battery in the Cressida to the boot...
For a relative layperson, what is involved in this...Obviously I'll have to run the earth to...earth, but what about the positive lead (and all the crap hanging off it). Is it just a matter of lengthening all those wires, forming a "loom" and running it thru the firewall and back thru the car to the boot or...what?
If what I want to happen in the future does, the relocation will be necessary... Smile
Re: Battery relocation... Tue, 11 February 2003 05:34 Go to previous messageGo to next message
You have to run a REALLY big wire from the back to the front. Nice and insulated with as little resistance as possible.
leebroozlee
Re: Battery relocation... Tue, 11 February 2003 05:49 Go to previous messageGo to next message
http://www.toymods.org.au/msgboard/index.php?t=msg &th=6876&start=0&rid=42&S=5455ed37 2686c57d7888d90af6b82308
Re: Battery relocation... Tue, 11 February 2003 12:32 Go to previous messageGo to next message
I did this in my Supra recently. You will need:
- proper sealed and vented battery box, securely attached to floorpan
- big fuck-off cable from battery -ve to a solid ground point on the chassis close to the battery (I used the rear seat belt anchor point)
- heavy-duty circuit breaker just after the battery, at least 100A (I used 150A but that may be overkill)
- battery isolation switch (optional, but a good idea)
- big fuck-off cable from battery +ve to the starter motor
- large-ish cable from the starter to a distribution point in the engine bay, which is where you attach everything that used to attach to the battery +ve
That's about it from memory. Nothing too taxing here, but it can be a bit of stuffing around if you're soldering the terminals on yourself, and routing the cable can be a whole lot of suck sometimes as well.
ROBBO_ma61
Re: Battery relocation... Tue, 11 February 2003 12:36 Go to previous messageGo to next message
may i ask why do you guys swap the battery to the back?
Re: Battery relocation... Tue, 11 February 2003 12:40 Go to previous messageGo to next message
To make room for a 2JZ. Very Happy
ROBBO_ma61
Re: Battery relocation... Tue, 11 February 2003 12:41 Go to previous messageGo to next message
thanks...shame its a damn lotta trouble ay.
biased99
Re: Battery relocation... Tue, 11 February 2003 23:18 Go to previous messageGo to next message
Don't need a 2JZ, as I have a 1UZ...
No, the relocation is so I can fit something "extra" in the space currently occupied by the battery...
PayneyCelica18rg
Southport
Re: Battery relocation... Tue, 11 February 2003 23:20 Go to previous messageGo to next message
A battery box is only about $20, and the only lead you need to run is the heavy duty positive. I had to do it cause of the size of my radiator. Plus with the big Spot lights I have, I wanted a bigger battery, which wouldn't have fitted in the origional spot even with the normal radiator... You will find a couple of plugged up holes in the fire wall anyway, so there isn't really any hard work...
Re: Battery relocation... Wed, 12 February 2003 00:10 Go to previous messageGo to next message
BOC make some really large wire that is heavily insulated. It is cheaper than the majority of auto electricians etc.
I paid $45 for 5 meters of it.
PayneyCelica18rg
Southport
Re: Battery relocation... Wed, 12 February 2003 00:30 Go to previous messageGo to next message
your right turbo? IO also used an earth lead off a welder. much better price range. ANd there is also bigger leads too. so if you want to push heaps of power, then you get a bigger lead...
Re: Battery relocation... Thu, 13 February 2003 05:31 Go to previous message
Just a note, Jaycar currently has a special on their 100amp circuit breakers.. $22 instead of $35 or there abouts.
I brought one today.
Previous Topic:single turbo 1ggte &were can get a 5 speed
Next Topic:2S-C Unleaded, and leaded
Current Time: Thu Nov 19 12:01:05 UTC 2026
Total time taken to generate the page: 0.0068461894989014 seconds
