Toymods » Tech & Conversions » Argh.. removing sheared off bolts.
M.W.P.
Rocky Mountains, Canada
Argh.. removing sheared off bolts. Wed, 12 February 2003 05:08 Go to next message
Hi all...
Just pulled the inlet manifold off the engine to try and solve a vaccum leak.
While doing so the three of the bolts that hold it to the exst manifold (its a 18R) sheared off right at the bottom of the thread.
I cant use multigrips or anything like that to remove them because there isnt any shaft i can get to.
I really dont want to drill them out either because the exst manifold is cast and itll be a bitch to tap new threads.
Thanks.
M.W.P.
Re: Argh.. removing sheared off bolts. Wed, 12 February 2003 05:12 Go to previous messageGo to next message
Here is a pic of one of the 3 bolts (well whats left).
http://www.overclockers.com.au/~mwp/temp/MVC-003F.JPG
[Updated on: Wed, 12 February 2003 05:13]
Blaze
Re: Argh.. removing sheared off bolts. Wed, 12 February 2003 06:50 Go to previous messageGo to next message
what you need to do is drill a small whole in the bolt, making sure you do it dead center. then you need to get a bolt removing tool. ( you can get one of these from any hardware shop or super cheap). the tool is similar to a drill bit but its thread is chunkier and in reverse. you slowly turn it inward and when it gets a firm hold it should start to turn the bolt.
Well that is what it is meant to do. give that a go.
ed_ma61
Lost in the K hole
Re: Argh.. removing sheared off bolts. Wed, 12 February 2003 09:46 Go to previous messageGo to next message
its called an "easy out"
might make trying to explain it to the local shop guy a bit easier.
if you do have to drill it out, dont worry, its easy enough to tap, and then just use a recoil kit.
ed
CamZH
Toodyay, WA
Re: Argh.. removing sheared off bolts. Wed, 12 February 2003 10:06 Go to previous messageGo to next message
Another idea might be to just replace the manifold?
I'm sure it'll cost about as much as the easy out, or less than the recoil kit!
Or just get extractors!
CamZH
M.W.P.
Re: Argh.. removing sheared off bolts. Wed, 12 February 2003 15:08 Go to previous message
Thanks guys.
I borrowed an "Easy Out"... got the 3 out without too many problems.
Previous Topic:intercooler help
Next Topic:aftermarket seats legalities
Current Time: Wed Nov 4 07:04:12 UTC 2026
Total time taken to generate the page: 0.079316139221191 seconds
