Toymods » Tech & Conversions » single turbo 1ggte &were can get a 5 speed
anthony84
syd
icon10.gif  single turbo 1ggte &were can get a 5 speed Wed, 12 February 2003 08:50 Go to next message
hi i got a 1ggte and i want to single turbo it what a good turbo i could use? and could i still use the stock computer?
also were could i find a 1ggte 5 speed????
Re: single turbo 1ggte &were can get a 5 speed Wed, 12 February 2003 11:07 Go to previous messageGo to next message
Ooooh, keeping the stock computer makes it a little harder unless you start playing silly buggers with the AFM etc. to try and 'make' it work. Probably best to aim for similiar power as a slightly boosted stocker e.g. nissan RB20 roller turbo, in which case why not keep the original ones?
riceboy
Japan
Re: single turbo 1ggte &were can get a 5 speed Wed, 12 February 2003 13:46 Go to previous messageGo to next message
Anthony have you looked at finding the stock single turbo and plumbing from the later model 1JZGTE? I don't know how compatible they are but i believe the turbo is a CT26?? Your 1GGTE has CT12 turbos right? If you decide to keep the twins can you just fit the larger CT12A turbos from the older 1JZGTEs? Isn't the IS200's engine block basically the same or originated from the 1GGTE? I have seen a few turbo conversions onto IS200s...guess it comes down to money. 5 speed? try a Jap wrecker...ask them if an IS200 6 speed will bolt up just for something different.
Re: single turbo 1ggte &were can get a 5 speed Thu, 13 February 2003 00:24 Go to previous messageGo to next message
First you have to work out what sort of power you are after. For all the stuffing around of the RB20 turbo, its not going to endow the engine with much more power at all.
Once you've worked out that, then go looking for a turbo that meets this level.
As for the gearbox, any Jap wrecker should have a W58 Supra 5-speed, they are pretty common. As for the IS200 6-speed...as long as it has the IS200 (G-series) bellhousing, it should bolt right up...be prepared to pay around $2000+ for it though.
Yeeehah
Re: single turbo 1ggte &were can get a 5 speed Thu, 13 February 2003 06:33 Go to previous message
goto Ray hall's website and use the turbo calculator, you might useful!
http://www.turbofast.com.au/TFmatch.html
Previous Topic:Talk about dodgy...
Next Topic:Battery relocation...
Current Time: Thu Nov 19 11:36:16 UTC 2026
Total time taken to generate the page: 0.0062079429626465 seconds
