Classifieds » Parts Wanted » IM SICK OF CARBIES I NEED EFI ! (2tg)
t_temperley
icon2.gif   IM SICK OF CARBIES I NEED EFI ! (2tg) Thu, 13 February 2003 07:22 Go to next message
Okay,next week we're going to have one last go at the carbies on the 2tg and if i cant get them at least a little more drivable then im looking to buy an EFI set up for it.
Whos got one ?
(I know rod has a manifold for sale, but i want something which is going to be LESS hassle than the cabies, i dont really want to have to piece a setup together.)
Tom
[Updated on: Thu, 13 February 2003 07:25]
IRA11Y
Club Member
Re: IM SICK OF CARBIES I NEED EFI ! (2tg) Thu, 13 February 2003 08:07 Go to previous messageGo to next message
what carbies are you running?
t_temperley
Re: IM SICK OF CARBIES I NEED EFI ! (2tg) Thu, 13 February 2003 11:06 Go to previous messageGo to next message
the stock ph 40 solexes
juzzo84
Hornsby, N.S.W
Re: IM SICK OF CARBIES I NEED EFI ! (2tg) Thu, 13 February 2003 12:33 Go to previous messageGo to next message
in about 2 weeks i may have a full 2tgeu for sale, with all running gear!!
JUZZO
0413461518
Pumpkin
Toymods Board Member
Re: IM SICK OF CARBIES I NEED EFI ! (2tg) Thu, 13 February 2003 22:54 Go to previous messageGo to next message
Rod's got the efi manifold....
I have the computer and AFM you can have.. and I could probably find the injector plugs for the loom.. Very Happy
Grega
melbourne.victoria.austra...
Re: IM SICK OF CARBIES I NEED EFI ! (2tg) Fri, 14 February 2003 03:07 Go to previous messageGo to next message
i've got the injector plugs if you're interested...and a bit of loom off the inlet manifold.
thetoyman75
Club President
icon10.gif  Re: IM SICK OF CARBIES I NEED EFI ! (2tg) Fri, 14 February 2003 05:23 Go to previous messageGo to next message
I also have the resitor thingy for the Injectors and the coil and Ignitor from an RA60 works fine which I also just happen to have Smile
Ohh and I have the plug for the AFM somewhere !
Grega
Re: IM SICK OF CARBIES I NEED EFI ! (2tg) Fri, 14 February 2003 05:48 Go to previous messageGo to next message
OK Rod wins Very Happy
juzzo84
Hornsby, N.S.W
Re: IM SICK OF CARBIES I NEED EFI ! (2tg) Fri, 14 February 2003 22:26 Go to previous messageGo to next message
well i have the AFM.
thetoyman75
Club President
icon10.gif  Re: IM SICK OF CARBIES I NEED EFI ! (2tg) Sat, 15 February 2003 11:36 Go to previous messageGo to next message
Ok sorry Stock Update !
I still have the plenum (Now minus TPS tho ! ) The Coil and Ignitor and injector bank are now spoken for sorry !
And if the truth be known... Now Grega Wins ! Wink
IRA11Y
Club Member
Re: IM SICK OF CARBIES I NEED EFI ! (2tg) Sun, 16 February 2003 06:55 Go to previous messageGo to next message
you have a PM
t_temperley
Re: IM SICK OF CARBIES I NEED EFI ! (2tg) Sun, 16 February 2003 12:09 Go to previous messageGo to next message
Okays so i guess complete setups are hard to come by.
Im still trying to get my head around this EFI thing so bare with me..
If i were to get the plenum off rod ,the computer,afm and injector bank off pumpkin,use a 4age tps,install a high pressure fuel pump i would have everything?
inferno
Re: IM SICK OF CARBIES I NEED EFI ! (2tg) Sun, 16 February 2003 12:50 Go to previous messageGo to next message
ok the 4age TPS will not work with the stock 2TGEU computer and rods plenuum has just been sold (to me Razz).
the parts you need depend on if you go aftermarket or stock. make sure you have the "yamaha" head water housing with the green EFI thermo connection, and electronic ignition (magnetic pickup dizzy, electronic coil and ignitor). you may also need a oxygen sensor put into your exhaust. and then there's the hassle of the wiring loom, which you will probably need to get wired by a specialist.
I sold my complete 2TGEU EFI gear last month for $350 becuase i needed the cash. Expect to pay at least $500 for EFI.
t_temperley
Re: IM SICK OF CARBIES I NEED EFI ! (2tg) Mon, 17 February 2003 09:00 Go to previous messageGo to next message
bugga
okay,now for more questions
i already have the magnetic pickup 2tgeu dizzy and im using a normal coil. everyone is talking about "electronic coils and ignitors"
somebody please explain?
could this be part of the reason my engine craps itself at about
2000 revs while under load? ie. not enough spark ?
tom
inferno
Re: IM SICK OF CARBIES I NEED EFI ! (2tg) Wed, 19 February 2003 13:06 Go to previous messageGo to next message
ummm... YES!! anyone correct me if i'm wrong but the way i see it- the magnetic pickup gets a tiny voltage drop due to the hall-affect magnetic field changing as the magnet passes the pickup, this voltage change between the two wires out of your dizzy are picked up from your ignitor and the ignitor acts like a relay and converts it into a bigger voltage drop, which earths the coil and creates the spark. the electronic ignition coils also use a higher voltage, therefore better, shorter, brighter spark. by using the old coil without ignitor the coil is getting a weak break in voltage and at high rpm the coil can't supply enough spark and the s*** hits the fan, hence the reason your engine "craps" itself.
the 2TGEU distributers are the rare part, use a 22RE ignitor and coil pack out of an RA6x celica, these bolt straight in, never had a prob with mine Razz .
get the coil and your ignition working properly, get your carbies tuned and you'll be laughing!
juzzo84
Hornsby, N.S.W
Re: IM SICK OF CARBIES I NEED EFI ! (2tg) Wed, 19 February 2003 19:42 Go to previous message
you can have all my fuel injection gear complete for $350
JUZZO
Previous Topic:22RE timeing chain cover wanted
Next Topic:WTB: 4agze supercharger
Current Time: Sat Nov 21 09:10:49 UTC 2026
Total time taken to generate the page: 0.0070991516113281 seconds
