Classifieds » Miscellaneous » 18r-gu bits
BlueRocket
Gippsland Victoria
18r-gu bits Fri, 14 February 2003 01:31 Go to next message
i was in the middle of rebuilding an 18r-gu when a turbocharged, injected 18r-g complete with supra gearbox fell into my lap Smile now i have a complete 18r-gu and 18r-c engine stripped down to the last nut and bolt ready for anyone who wants it. (no new parts in it but the old ones are in good condition)
russs
Turramurra
Re: 18r-gu bits Fri, 14 February 2003 02:14 Go to previous messageGo to next message
Would love to buy the distributor and cap.
Jason
Re: 18r-gu bits Fri, 14 February 2003 02:38 Go to previous messageGo to next message
Dont spose you have any injection bits for sale?
Re: 18r-gu bits Fri, 14 February 2003 03:57 Go to previous messageGo to next message
what size valves does your 18-rgu head have, and what compression pistons do you have for the twincam motor?
shinzui
Re: 18r-gu bits Fri, 14 February 2003 15:28 Go to previous messageGo to next message
How much for a timing case?
any idea how much postage to bris would be? Smile
BlueRocket
Gippsland Victoria
Re: 18r-gu bits Fri, 14 February 2003 21:09 Go to previous messageGo to next message
i dont know the proper way to measure the valves so i measured the hole that it covered
intake 40mm
exhaust 34mm
the engine has duel solex carbies (so no injection equipment)
i am happy to get rid of the motor in pieces so long as i know i can get rid of the head and carbies. if so;
timing case (i assume thats the proper name for the front chain cover) $50 (or somthing) i donno what the postage would be.
distributer & cap (points system) $10
Re: 18r-gu bits Sat, 15 February 2003 06:46 Go to previous messageGo to next message
what is the numbers on the head of your engine? should be something like 11111-88230??
can you tell me if your pistons have BIG looking domes on top, or can you get a pic of them to me? if they are the ones im after ill take them off your hands!
BlueRocket
Gippsland Victoria
Re: 18r-gu bits Sun, 16 February 2003 03:49 Go to previous messageGo to next message
the head numbers are 88253
the motor looks very origional and the pistons are in quite good condition. they do have the domes in them and the valve groves in the top so they would be either 9.7-1 or 9.2-1 (im not too sure which ones)
just found out the new motor has custom pistons that cost $2000+ designed for the professionaly fitted turbo Very Happy
just thaught i would share that
BlueRocket
Gippsland Victoria
Re: 18r-gu bits Mon, 17 February 2003 02:42 Go to previous messageGo to next message
This is a picture of the piston. its a little fuzzy cos its a cheap digital camera
Attachment: Piston.JPG
(Size: 48.73KB, Downloaded 37 time(s))
russs
Turramurra
Re: 18r-gu bits Mon, 17 February 2003 23:26 Go to previous messageGo to next message
I have sent you an email about the dizzy.
I can put the money direct into your account.
Let me know.
BlueRocket
Gippsland Victoria
Re: 18r-gu bits Wed, 19 February 2003 16:20 Go to previous messageGo to next message
errrr, i think i just acedently deleted your email in the midst of all the junk email. can u send it again (sorry)
wil8115
Seattle area, USA
Re: 18r-gu bits Tue, 18 March 2003 08:45 Go to previous messageGo to next message
BlueRocket wrote on Sun, 16 February 2003 14:49
88253 is the big valve head...great starting platform.
the 18RGU has either 8.7 or 8.4 depending on Serial #
if the block & head are from the same "engine" that was factory
built. The Serial #(Not the head casting #)is located just over
the #1 cyl exhaust port on a small tab that sticks out just under the valve cover surface. My #88253 18RGU has a Serial number of 87???.. very late 18rgu
blackRA28
adelaide
Re: 18r-gu bits Tue, 18 March 2003 10:54 Go to previous messageGo to next message
Do the higher-comp pistons fit straight into a later efi motor? ie an efi 18rgeu -88270 head
this would be a great way of increasing N/A power if u wanted to rebuild..
munki
Gold Coast
Re: 18r-gu bits Tue, 18 March 2003 12:30 Go to previous messageGo to next message
how much for the lot? how much do you think transport up to queensland would be.
please PM me
Daniel
wil8115
Seattle area, USA
Re: 18r-gu bits Thu, 20 March 2003 10:48 Go to previous message
blackRA28 wrote on Tue, 18 March 2003 21:54
yes they do.
as a matter of fact use the early block also if you have it.
They have thicker cyl walls and can "take more heat" hint hint, wink wink. Wink
Previous Topic:44 Solex's For Sale $200ono
Next Topic:RA23 Towbar and box of goodies,
Current Time: Fri Nov 20 10:39:33 UTC 2026
Total time taken to generate the page: 0.0071320533752441 seconds
