Toymods » Tech & Conversions » 4AGE - Air Fuel Mixture
SW20R
4AGE - Air Fuel Mixture Fri, 14 February 2003 23:35 Go to next message
Just wanted to know if it is located ontop of the throttle body?
There's a flat head shape adjuster. I told my dad the idle was there, he said no. Thats for the air fuel mixture. The idle is on the throttle linkage/connector. We'll he fixed my ilde up problem (Car would start but; would die unless you gave it some gas. it was that little screw on the linkage) Now it idles at 1500RPM even after 2minutes of warming up on first start for the day. What could it be? I want to adjust that screw but he told me not to play with the mixture. Funny how he knew what was happening with my idle up.. i doubted him becuase he drives a carby
leebroozlee
Re: 4AGE - Air Fuel Mixture Fri, 14 February 2003 23:41 Go to previous messageGo to next message
maybe he just tightened it too much.
try blipping the throttle..this happened to my car once when my brother played with it, and blipping the throttle would bring the revs back down after. While sitting at lights the revs refused to drop below 2000..you'd have to floor it then let go quickly. But this was all because he had tightened it too much anyway.
SUPRAGTE
North Sydney
Re: 4AGE - Air Fuel Mixture Fri, 14 February 2003 23:47 Go to previous messageGo to next message
You gooses! The a/f mixture is set and controlled through the computer.
SW20R
Re: 4AGE - Air Fuel Mixture Sat, 15 February 2003 00:02 Go to previous messageGo to next message
yeah thats what i was telling him..
so it is the idle then?
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: 4AGE - Air Fuel Mixture Sat, 15 February 2003 00:06 Go to previous messageGo to next message
Yeah man, that's the idle adjustment for sure.
Play with it all you like, clockwise should lower the idle, anti-clockwise will raise it.
IRA11Y
Club Member
Re: 4AGE - Air Fuel Mixture Sat, 15 February 2003 02:31 Go to previous messageGo to next message
heres how to do it
Idle Adjustment MPEG
SW20R
Re: 4AGE - Air Fuel Mixture Sat, 15 February 2003 03:53 Go to previous messageGo to next message
cheers mick
TA22-3SGTE
MACKAY
Re: 4AGE - Air Fuel Mixture Sat, 15 February 2003 09:00 Go to previous messageGo to next message
The screw on the linkage is adjusted to just hold the butterfly open slightly so it wont close tight in the throttle body , The screw in the top of the throttle body is for idle adjustment , Some map sensed 4AGE'S had an electronically adjustable idle a/f ratio , It should be in the engine bay somewhere .
Trevor
Grega
melbourne.victoria.austra...
Re: 4AGE - Air Fuel Mixture Sat, 15 February 2003 21:51 Go to previous message
the very very early 4AG's had electronically adjustable - they ran no o2 sensor but a resistor which you'd use with a air/fuel meter up the pipe to tell if you were on the money or not...
Previous Topic:ST184 Celica comments???
Next Topic:what is the flow rate of 5mge external fuel pump
Current Time: Wed Oct 21 14:46:30 UTC 2026
Total time taken to generate the page: 0.091779947280884 seconds
