Toymods » Tech & Conversions » Camry Alloy V6 Motor
1UZ FTE
Camry Alloy V6 Motor Mon, 17 February 2003 21:53 Go to next message
Require any information on the Alloy Camry V6
performance figures compression ratio's, bore stroke etc
pictures in the car and preferably removed from car, weight of engine gearbox or both, approx length & widths of motor
information on the gearbox and ratio's would be great as well
Last question does anyone know what they are approx worth at the wreckers
Pics can be emailed to j@yackandandah.com
J
rob_RA40
c'town, NSW
Re: Camry Alloy V6 Motor Mon, 17 February 2003 22:36 Go to previous messageGo to next message
hey,
you've probably been here but ill post it anyways. did u check out this link at all
http://www.geocities.com/MotorCity/Pit/9975/dataBy Subject/GasolineEngines.html
this website is pretty well know by now.
HTH
Re: Camry Alloy V6 Motor Tue, 18 February 2003 01:02 Go to previous messageGo to next message
Which Camry V6 mate?
Re: Camry Alloy V6 Motor Tue, 18 February 2003 01:12 Go to previous messageGo to next message
The alloy ones, 1MZFE or 2MZFE. I believe one series has a head gasket issue, but I'm not sure if it's the MZ or VZ series.
EDIT: A range of pics here, including one that grenaded!
http://www.legacytuning.com/glok/
[Updated on: Tue, 18 February 2003 01:17]
1UZ FTE
Re: Camry Alloy V6 Motor Tue, 18 February 2003 02:01 Go to previous messageGo to next message
thanks for the reply's guys and links
this maybe a dum question but which model motor does oz get do we get the alloy 1mzfe series or the 2mzfe
I've also been told that these motors are produced locally ??
j
Re: Camry Alloy V6 Motor Tue, 18 February 2003 02:34 Go to previous messageGo to next message
The MZ series V6's (all alloy) are found in current Camry's and Avalons. The VZ series (iron block) are found in older Camry's.
Soarer
Wollongong
Re: Camry Alloy V6 Motor Tue, 18 February 2003 03:51 Go to previous messageGo to next message
Eeek, keep away from the 3VZ-FE. I managed to kill one at 60,000km on the clock. 2 broken conrods, lots of holes in the block, and a cracked block (3 pieces).
This was doing 70km/h at around 4,500rpm.
Most unreliable engine I've ever seen.
Don't expect to extract much extra power out of the 1MZ either. Apparently not very tunable at all, being a FE type engine.
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
icon2.gif  Re: Camry Alloy V6 Motor Tue, 18 February 2003 03:52 Go to previous messageGo to next message
We get the 1MZ-FE I think.
Not sure if they're produced locally or not... The cars are but the engines might be transported from Japan...
Re: Camry Alloy V6 Motor Tue, 18 February 2003 09:54 Go to previous messageGo to next message
The FE type engines aren't the top of the top, but they have to be tunable to an extent, look at the upgrade stuff for the 1UZFE Very Happy
Re: Camry Alloy V6 Motor Tue, 18 February 2003 10:13 Go to previous messageGo to next message
Hmmm, I had once thought about supercharging a VZ engine in my car, just to be different, but ended up using a turbo'd 4ag simply for ease/cost reasons. Would have been interesting to see how strong the engine was when I pulled it down though.
1UZ FTE
Re: Camry Alloy V6 Motor Tue, 18 February 2003 21:25 Go to previous messageGo to next message
Hmmmm I wonder if these 1MZFE & 2MZFE engines have a similar 6 bolt bottom end as per the 1UZFE
If the heads are similar to the 1u in flow characteristics at low lift and combustion chamber design then it would be just what i'm chasing
The plan was to turbocharge one of these in a low boost application of around 7-12psi depending on the variables
Next problem is if the gearbox would handle the extra go (Torque)
What type of box is behind them are they as beefy as the later model 3sgte MR2 boxes,
if i can get enough specs on these to satisfy myself that it would be a worth while project and the cost of a complete front cut was reasonable ,.....i would have to go ahead with it
j
[Updated on: Tue, 18 February 2003 21:33]
rob_RA40
c'town, NSW
Re: Camry Alloy V6 Motor Tue, 18 February 2003 21:39 Go to previous messageGo to next message
jamie are you thinking of keeping it in FWD format? they are mounted on quite a slant (can hardly get to the rear banks plugs) and you might have troubles if its for RWD application..
Re: Camry Alloy V6 Motor Wed, 19 February 2003 00:19 Go to previous messageGo to next message
I think he's planning it in mid-engine format.
The box is obviously the V6 Camry box which is supposed to be pretty strong, although I would assume the MR2 box is stronger and is more likely to have the option of LSD.
I doubt the 1MZFE would have the 6-bolt mains of the 1UZFE, but there may be potential with the head, problem is no one has really gone all out with them because they are only available in FWD.
1UZ FTE
Re: Camry Alloy V6 Motor Wed, 19 February 2003 02:24 Go to previous messageGo to next message
Rob,...Justcallmefrank is right, it is going into a mid engine configuration
these cars currently run the 3sge or 3sgte motors and box and we are trying to look at an appealing engine package as an alternative to a 4cyl for the next batch of compliance
the cars come in either turnkey or kit form
http://allison.yackandandah.com/index.htm
the web site is preliminary
J
wagonist
Toymods Club Treasurer
Re: Camry Alloy V6 Motor Wed, 19 February 2003 04:49 Go to previous message
I heard that the manual boxes from the 3L motor were the same as the GT4, just minus the rear coupling
Previous Topic:22r hilux has run on and pinging, what causes this?
Next Topic:4efte into a TERCEL........
Current Time: Sat Nov 21 09:58:02 UTC 2026
Total time taken to generate the page: 0.0075359344482422 seconds
