Toymods » Tech & Conversions » 22r hilux has run on and pinging, what causes this?
gibbo
Adelaide SA
22r hilux has run on and pinging, what causes this? Mon, 17 February 2003 23:38 Go to next message
My engine runs on, usually on warmer days, and pings when I try to accelarate from about 100kph in 4th gear, also when the pedal is at the point where the second throat is just about to open , I get pinging too.
The motor has done 275000kms, and there is a bit of smoke when I start it up sometimes.
Any ideas? (besides "the motor is rooted!)
Re: 22r hilux has run on and pinging, what causes this? Tue, 18 February 2003 02:39 Go to previous messageGo to next message
Check your ignition timing; if it's too advanced it can cause both of these problems. Another possible cause is carbon buildup, which can be dealt with by pouring water into the engine while it's running at 2-3000 rpm.
gibbo
Adelaide SA
Re: 22r hilux has run on and pinging, what causes this? Tue, 18 February 2003 06:19 Go to previous messageGo to next message
The timing is set to 5dbtc as the book says, might have to try the water trick, how much water? I guess it would be just a light spray?
Re: 22r hilux has run on and pinging, what causes this? Tue, 18 February 2003 12:00 Go to previous messageGo to next message
Nope, pour in a steady stream from a jug. As long as the engine is revving a bit this will be fine. It you notice brown smoke coming out the tailpipe, this means it's working (ie the carbon is being dislodged and spat out).
wilbo666
Re: 22r hilux has run on and pinging, what causes this? Tue, 18 February 2003 13:30 Go to previous messageGo to next message
Never heard of that? Water in a motor! Hmm, how does it work exactly do you know?
BansheeBuzz
Gold Coast
Re: 22r hilux has run on and pinging, what causes this? Tue, 18 February 2003 20:31 Go to previous messageGo to next message
Hiluxs are notorius for pinging. Use premium fuel, it will help. You don't really want to back off the timing anymore cause it will become real slugish.
As for the water deal i've never heard of that b4 so i cant comment but note this - if too much goes down your motor will not be able to compress it and chances are you will bend a rod.
Re: 22r hilux has run on and pinging, what causes this? Tue, 18 February 2003 23:18 Go to previous messageGo to next message
That's true, but you'd pretty much have to dump a bucket of water down the inlet to make it hydraulic lock. Think about how much air is being consumed by your engine at 3000rpm, and you'll see there's no danger pouring water out of a jug into your engine.
The idea behind this is the water flashes into steam in the combustion chamber, and this blasts the carbon away. It can be very effective if there's lots of carbon in your engine.
knackers
berala sydney
Re: 22r hilux has run on and pinging, what causes this? Wed, 19 February 2003 04:52 Go to previous messageGo to next message
hi gibbo
i have a complete 22r with 5 speed every thing to go just pulled it out of my hilux .Nothing wrong with it has 180k on it
So if you what a motor ring me 0412106269 every thing is on this motor, clutch fan to tail shaft
cya knackers
gibbo
Adelaide SA
Re: 22r hilux has run on and pinging, what causes this? Wed, 19 February 2003 04:56 Go to previous message
Thanks knackers, but I would rather whack in something with a bit more guts than the old 22r if I start pulling engines out! Very Happy
I have tried premium unleaded, that didn't change the pinging at all,I am going to try the water pouring trick, will let you know how it goes!
[Updated on: Wed, 19 February 2003 05:01]
Previous Topic:removing 4AGE valve stem seals....How??
Next Topic:Camry Alloy V6 Motor
Current Time: Sat Nov 21 09:50:05 UTC 2026
Total time taken to generate the page: 0.0066959857940674 seconds
