Classifieds » Parts Wanted » Mark II Corona rear axle
ddeane
PNG
Mark II Corona rear axle Wed, 12 June 2002 01:49 Go to next message
Gidday
I am trying to locate a Mark II Corona rear axle assembly (drum to drum)
Craig
Dylo
Re: Mark II Corona rear axle Wed, 12 June 2002 02:31 Go to previous messageGo to next message
G'day there Craig.
It's dylan here, so you have decided that the MKII Corona is the go? are they proving a little hard to find now?!
I sent u an email regarding this the other week, but my Email company kindly decided to close down all together. My new Email is now:
Dylanis@mail.com
So will the discs you have cross over ok on to this diff?
I got a new set of rims now, and the offset is perfect. the diff looks like it belongs in there, but i have slight problems up the front as the inner edge of the tyre JUST touches the strut. I think i may need to space them out about 2mm. I think i remebered you telling me you had spacers? If so, where can you get them? and whats the go, are they legal? what thicknesses are available?
ddeane
PNG
Re: Mark II Corona rear axle Thu, 13 June 2002 09:53 Go to previous messageGo to next message
Dylan
I did reply to your email, must have been after you lost you ISP. You can get 6mm spacers from Pat's Tyres at Mitchell (only at Mitchel). I am not sure that rego would notice 6mm but in any event all you have to do is have one set screw to the hub flange to have them legal. The spacers that I have are for the back and they are 25mm and they bolt ro the original studs and have new studs on the spacers.
The 6mm spacers will surely fix your problem - they are about $20 ea.
If you have any other problems give me a ring on 62369110 at nite.
Craig
thetoyman75
Club President
Re: Mark II Corona rear axle Thu, 13 June 2002 09:58 Go to previous messageGo to next message
Ddeane,
What model Mk II The first (Shovelnose) or the second version (MX23 type) ?
Dylo
Re: Mark II Corona rear axle Thu, 13 June 2002 16:20 Go to previous messageGo to next message
Rod.
mine came from the 4 door version MKII Corona, with the old 6 cyl in it. its an 'F' series and fits like a dream : P
pics should be up soon.
ddeane
PNG
Re: Mark II Corona rear axle Sat, 15 June 2002 05:49 Go to previous messageGo to next message
thetoyman75 wrote on Thu, 13 June 2002 7:58 PM
Ddeane,
The second version with the 4M in it.
Craig
Re: Mark II Corona rear axle Mon, 17 June 2002 11:36 Go to previous messageGo to next message
OK I will have a spare one in a couple of months. F312 ratio. Complete drum to drum. If you don't find one in that time email me.
Dylo
Re: Mark II Corona rear axle Tue, 18 June 2002 14:30 Go to previous messageGo to next message
Hey Craig,
Have you tried Steves Spares, in QBN?
...just a thought mate, havent been there in a while but he used to have a heap of old Toyo's.
TOY77
Re: Mark II Corona rear axle Wed, 19 June 2002 08:05 Go to previous messageGo to next message
Hi guys,
What are you using these diffs for?
Stew
Dylo
Re: Mark II Corona rear axle Wed, 19 June 2002 15:00 Go to previous messageGo to next message
G'day Stew.
I'm Using one in my RA23, they fit quite well after the mounts are moved. They are an F series diff and have the potential for an LSD that bolts right in Razz
TOY77
Re: Mark II Corona rear axle Thu, 20 June 2002 07:18 Go to previous messageGo to next message
ok cool,
How much do you look at for this?
How strong are they?
What are the lsd's like for them and cost?
I have a ra28 but i'm looking at using a volvo diff.... for simmilar reasons, but these are extremely strong... so i'm told (from reliable sources).
Stew
ddeane
PNG
Re: Mark II Corona rear axle Thu, 20 June 2002 10:57 Go to previous messageGo to next message
Dylo
managed to get hold of one at jap spares - cost more than the car you bought.
To the other query - they are in effect a hilux diff - the axles are some 8mm wider than the 23 ones. The advantahe is that the width is 60mm more than the standard diff which allows you ro bolt up normal offset wheels (30mm) combined with xt130 hubs on the front thing work out real well. I also thing that the Avanti disk brakes will bolt up with minimum modification if any - although I have to confirms this by doing it.
A diff place in the ACT has built a jig to allow the welding up if the suspension bits from the 23.
Craig
GEEZE23
Western Sydney
Re: Mark II Corona rear axle Thu, 25 July 2002 13:51 Go to previous messageGo to next message
The pres. has a MK2 last model w/ the F-series 7.5, same as early supra, can convert it to LSD. He might part with it cheap, but the there is also a complete last model two dr i know of in Riverstone, sydney for $100! Rod also knows where this - he will need the fuel filler. The car has a hole in the block and a fair body- and rolls.
Dave
thetoyman75
Club President
Re: Mark II Corona rear axle Thu, 25 July 2002 23:53 Go to previous messageGo to next message
Dave,
Shhhh on the Rivertone one Wink Hopeing to shoehorn its diff into the Showcar Smile
Will talk to you soon about heading out to pick it up Smile
(Maybe next week/weekend)
Rod.
TOY77
Re: Mark II Corona rear axle Fri, 26 July 2002 09:52 Go to previous messageGo to next message
How wide are the diff from end to end?
i think the 2wd hilux is 1400mm
and my ra28 is 1370mm
does this sound right?
GEEZE23
Western Sydney
Re: Mark II Corona rear axle Sat, 27 July 2002 05:12 Go to previous message
Havent measured the MX23, the RN46 2wd hilux is 1415mm or 1425mm, cant remember, but definetely wider than 1400. mine fit in fine and looks heaps fatter!!! + 8in diff + Detroit locker + GZE6 = lots of easy sideways motion Smile
Dave
Previous Topic:TA22 passenger gaurd
Next Topic:(Non Car) WTD: Stereo Amplifier
Current Time: Mon Oct 26 08:42:18 UTC 2026
Total time taken to generate the page: 0.0075180530548096 seconds
