Classifieds » Miscellaneous » Garage Clean Out (A70 Supra Bits)
wastegate
Gold Coast
Garage Clean Out (A70 Supra Bits) Tue, 18 February 2003 00:58 Go to next message
Guys/Gals
Need to clear some room out of the garage and also selling some stuff from a friends garage as well.
1x Broken R154 (changes gear but I'm 99.9% Sure the 1st gear thrust washer has broken I have already repaired it once for this for $400 for parts and labour) comes with bellhousing to suit M Series. Looking for around $400.
1x Clutch Pressure Plate 3400lb and 5puck drive plate, no flywheel built by Jim Berry's RaceClutch. $200
1x 7M Short Block, needs rebuild. Offers.
1x R154 perfect working order with clutch and flywheel $1500 Located in Sydney
1x Race Prepped 7M Engine Mods include:
comes with Ross forgies, ceramic coated tops and skirts, combustion chamber and exhaust ports and valves.
Ported intake and exhaust ports - CC'd combustion chambers.
ARP head & main studs, and ARP rod bolts.
O ringed block, o ringed head (receiver grooved to be technically correct).
Head has been machined to suit the big cams.
Valve springs have been upgraded to 100lb base seat pressure, supporting
14mm of lift.
Block has had the oiling system modified for better flow and drainage.
Crank has been linished and nitrided. Rods have been beam polished and
double shot peened.
Also comes with harness and manual ECU, 2 spare blocks, a spare head, 2
spare cams, a spare crank, 6 spare rods, 6 factory pistons, and other
miscellaneous bits'n'bobs which my father would love for me to get rid of
so he can have his shed back Wink
$4000 Located in Sydney
1x TRD Cams suit 7M Cams are 10.88mm lift, 256 deg @ 50thou on the intake, 243 degs on the exhaust - $1500 Located in Sydney
6x Stock 7M 440cc Injectors $100
ALOT of other MA70 Stuff, if you need something I can have a look.
ed_ma61
Lost in the K hole
Re: Garage Clean Out (A70 Supra Bits) Tue, 18 February 2003 01:17 Go to previous messageGo to next message
im guessing the clutch is for the r154???
do'h! (in advance)
and secondly - this race prepped block: gte or ge? the pistons, both those installed and the spare factory low or hi comp?
ed
wastegate
Gold Coast
Re: Garage Clean Out (A70 Supra Bits) Tue, 18 February 2003 01:25 Go to previous messageGo to next message
Yes the Clutch is for a R154.
The Built 7M is a GTE with Turbo (CT26) has done about 3000kms.
? Not sure what you mean here.. Which motor are you talking about? Have a couple of spares here.
Manny
Re: Garage Clean Out (A70 Supra Bits) Tue, 18 February 2003 08:38 Go to previous messageGo to next message
Interested in the R154 clutch.
What condition is the clutch in, how old is it, do you have pics?
Will you separate the shifter on the broken R154?
wastegate
Gold Coast
Re: Garage Clean Out (A70 Supra Bits) Tue, 18 February 2003 12:05 Go to previous messageGo to next message
Hope someone buys the Built 7M, it really is a bargain, cost $8000 to get all the work done to it. ALOT of labour in it.
Manny: The clutch is about 6 months old.
Here is a picture
http://board.performanceforums.com/gallery/data/500/25puck-med.jpg
http://board.performanceforums.com/gallery/data/500/21-med.jpg
[Updated on: Tue, 18 February 2003 12:09]
ed_ma61
Lost in the K hole
Re: Garage Clean Out (A70 Supra Bits) Tue, 18 February 2003 13:16 Go to previous messageGo to next message
i would literally kill for those cams dammit!
ed
[Updated on: Tue, 18 February 2003 13:17]
wastegate
Gold Coast
Re: Garage Clean Out (A70 Supra Bits) Tue, 18 February 2003 22:03 Go to previous messageGo to next message
TRDs
http://board.performanceforums.com/gallery/data/500/2camshafts_4-med.jpg
TRDs vs Stock Cams
http://board.performanceforums.com/gallery/data/500/2camshafts_6-med.jpg
ed_ma61
Lost in the K hole
Re: Garage Clean Out (A70 Supra Bits) Wed, 19 February 2003 01:13 Go to previous messageGo to next message
please please please give them to me Razz
ill be your friend...
Sad
ed
ed_ma61
Lost in the K hole
Re: Garage Clean Out (A70 Supra Bits) Wed, 19 February 2003 02:23 Go to previous messageGo to next message
in a desparate, pathetic, broke student, eats catfood kind of way, ill offer $300 for the cams.
hopeless, lowly, and rather fruitless i admit, but i wouldnt be able to live with myself unless i actually asked...
Sad
ed
wagonist
Toymods Club Treasurer
Re: Garage Clean Out (A70 Supra Bits) Wed, 19 February 2003 04:59 Go to previous messageGo to next message
Don't happen to have an intercooler from an MA70?
wastegate
Gold Coast
Re: Garage Clean Out (A70 Supra Bits) Wed, 19 February 2003 05:41 Go to previous messageGo to next message
I do, think is it's a little damaged, has a dent in the bottom of it. Doesn't leak, I was running 12psi on it for 12 months like that. $50+shipping?
ed_ma61
Lost in the K hole
Re: Garage Clean Out (A70 Supra Bits) Wed, 19 February 2003 05:48 Go to previous messageGo to next message
ill take that as a 'no' .....
wastegate
Gold Coast
Re: Garage Clean Out (A70 Supra Bits) Wed, 19 February 2003 05:53 Go to previous messageGo to next message
Very Happy yeah it's alittle bit of a discount there Very Happy
ed_ma61
Lost in the K hole
Re: Garage Clean Out (A70 Supra Bits) Wed, 19 February 2003 06:01 Go to previous messageGo to next message
Rolling Eyes
you noticed huh ??
Rolling Eyes
well, if you get desparate, you know where to turn. id snap them up in a jiffy!! Crying or Very Sad
ed
wagonist
Re: Garage Clean Out (A70 Supra Bits) Wed, 19 February 2003 20:41 Go to previous messageGo to next message
I'm coming up to Brissie for the second week in March.
If you're prepared to hold onto it till then, I'll take the intercooler.
SUPRA MAN
Re: Garage Clean Out (A70 Supra Bits) Mon, 10 March 2003 15:15 Go to previous messageGo to next message
You wouldnt happen to have a strut /brace bar for a MA70 supra ?
I am also after any sort of aftermarket air intake system, airpod, and pipes, also for MA70 Supra.
Any other bolt on performance bits, or show parts also wanted. I would cover all postage costs.
Those cams are very tempting, but I cant bring myself to spend that much.........
SUPRA MAN
Re: Garage Clean Out (A70 Supra Bits) Thu, 01 May 2003 08:02 Go to previous messageGo to next message
You have a PM.
turbokid
Re: Garage Clean Out (A70 Supra Bits) Thu, 08 May 2003 12:05 Go to previous messageGo to next message
got and interior stuff? how bout the black plastic intake pipe with the resonater thing? dont want the airflow meter or anything just the intake pipe.
slylux
perth WA
    nup
Re: Garage Clean Out (A70 Supra Bits) Thu, 08 May 2003 12:39 Go to previous messageGo to next message
whats the best price on the broken R154 .. i dont need the bell housing
hks89supra
Re: Garage Clean Out (A70 Supra Bits) Tue, 13 May 2003 00:51 Go to previous messageGo to next message
do you have the standard radiator shroud or by the off chance thermo fans for it.
Helmann
Ipswich
Re: Garage Clean Out (A70 Supra Bits) Tue, 13 May 2003 07:25 Go to previous messageGo to next message
I am after the moulding around the windscreen. Do u have the top and both sides?
Any 550cc injectors?
What about a complete exhaust from dump pipe back? 3" mandrel?
Front spoiler lower lip???
Any other performance bit?
punkdefender
Dandenong/VIC
Re: Garage Clean Out (A70 Supra Bits) Wed, 14 May 2003 12:22 Go to previous messageGo to next message
in what condition are the injectors? is the fuel rail included?if not would they fit the 1g-gte fuel rail or would I have to source a fuel rail from a 7M?
mx83toy
Re: Garage Clean Out (A70 Supra Bits) Tue, 17 June 2003 15:16 Go to previous messageGo to next message
Is that R154 in Sydney still for sale??? was it once bolted behind a 1J (this is what i want to put it behind)
BansheeBuzz
Gold Coast
Re: Garage Clean Out (A70 Supra Bits) Tue, 17 June 2003 21:18 Go to previous message
do you still have the broken r154? is it located on the gold coast?
Previous Topic:1GGTE Series II ECU FS
Next Topic:Vic Personal Plate for Sale
Current Time: Fri Nov 20 08:14:30 UTC 2026
Total time taken to generate the page: 0.017462015151978 seconds
