Toymods » Tech & Conversions » Small port + Bigport cams
SW20R
Small port + Bigport cams Tue, 13 January 2004 10:48 Go to previous message
I have spare bigport cams and thinking of installing them this weekend. The bigport has a higher lift and duration? so it should give a few more kw advantage? What are your thoughts? give it a go or dont bother?
Duration
Lift
Intake opening
Exhaust opening
Comments
Smallport 4AG
232°
7.1mm
8°BTDC
47°BBDC
Stock 4AG(Z)EU used on 90~91 Hi-comp. AE92 and supercharged AW11. P/N Intake 13501-16030. Ex. 13502-16020, Good turbo cam. Keeps exhaust pressures high without blowing back though intake manifold.
Bigport 4AG
240°
7.56mm
9°BTDC
(Stock -max lift @ 111°)
51°BBDC
Stock 4AGEU used on AE86 and AW11. P/N Intake 13501-16010. Ex. 13502-16010. Some have found good power setting the maximum lobe lift for the exhaust at 100°BTDC and intake at 100°ATDC. For more bottom end power retard the exhaust 4° and advance the intake 3°. For more top end, advance intake 4°and exhaust 3° from stock settings.
Also will this change the sound characteristics? I really love the roar of the tvis motor over the small port.. is that with the intake? or cams?
[Updated on: Tue, 13 January 2004 10:54]
Read Message   Small port + Bigport cams  SW20RTue, 13 January 2004 10:48
Read Message   Re: Small port + Bigport cams shinybluesteelTue, 13 January 2004 11:58
Read Message   Re: Small port + Bigport cams slydarTue, 13 January 2004 12:14
Read Message   Re: Small port + Bigport cams FKN16VWed, 14 January 2004 12:46
Read Message   Re: Small port + Bigport cams IRA11YThu, 15 January 2004 06:44
Read Message   Re: Small port + Bigport cams ae86driftThu, 15 January 2004 09:40
Read Message   Re: Small port + Bigport cams mrshinThu, 15 January 2004 10:52
Read Message   Re: Small port + Bigport cams FKN16VWed, 15 September 2004 11:58
Read Message   Re: Small port + Bigport cams HennWed, 15 September 2004 13:35
Previous Topic:7MGTE into Mx62 ?
Next Topic:Something Wrong
Current Time: Tue Oct 27 12:45:10 UTC 2026
Total time taken to generate the page: 0.009425163269043 seconds
